Gear box
howiedean
Unread post by howiedean »
johninderbyshire wrote:anyone know how much i could get for it selling it with a noisy bearing???
Mint condition, 6 disc clarion changer, 4 michelin tyres, just had new head gasket and full service inc water pump, tensioner pulley and cam belt, mot jan 07, air con, climate control, exhaust with reciept for warranty for three years, etc I have a number of parts to sell with it including a new temp sensor for the climate control (it works fine, the wife was just going into overdrive), power steering fluid, gear box oil, some left over gaskets,
It's better to get it fixed. I'd try and locate a gearbox speacialists and find out what they think. I'd suspect you could get it recon'd for around £350-£400. Failing that I'll give you £650 for it. :twisted:
Regards
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
johninderbyshire
Unread post by johninderbyshire »
i think i will get it fixed. lol :P
citroenbx
Unread post by citroenbx »
Hi there..No disrespect but just take your car to Citroen specialist and have him/her have a look at it.
Dont throw away anymore money..If you have a faulty box it would be unusual.
It could be a multitude of things and hopefully you can be back on the road soon with little outlay..Worst case senario you need a second hand box fitting ?
I'd always say sort it yourself but when you talk about selling up its always time to hand it over and save the pain.
Cheers
Life feels good just as you complete No4 Glow Plug on a ZX-TD
johninderbyshire
i have done nothing but spend on it. There can't be much else to go wrong. It still drives fantastic, but just has a noise.
Its the brother in law that does all my mechanic work, and he doesn't want to do the gearbox/clutch.
I paid £5000 two year ago, and i know its worth nought really :(
dnsey
x 19
Unread post by dnsey »
Some of the bigger breakers will supply and fit a second-hand box very reasonably.
It might be worth asking around.
howiedean
johninderbyshire wrote:i have done nothing but spend on it. There can't be much else to go wrong. It still drives fantastic, but just has a noise.
John,
Don't do anything silly and sell the car as it is just now!!!
Go to a couple of independent garages and try to find out what is wrong. You never know it might not be as expensive as you think.
regards
Howie
matt
Unread post by matt »
Hi john in derbyshire.if your anywhere near chesterfield,try walgrove garage,independent cit garage(or were last time i drove by)
92 205 1.9 GTI(MODIFIED,SORRY )
1996 VOLVO 850 2.5 5CYL 10V
1999 EXPERT VAN TD - WHITE !
No more car's thanks!
johninderbyshire
i am in chesterfield. wheres this garage exactly?
matt
Its on Walgrove Road round the back of Morrisons in Brampton,may be worth a try?
fastandfurryous
x 4
You're probably best off taking it to a Gearbox specialist.
Given that the noise is in all gears, but only on over-run it is almost guaranteed to be a failed endfloat washer, a loose circlip, or possibly a partially failed bearing. All of which are cheap components, it's just the labour needed to get to it.
Find someone who is well versed in stripping a gearbox, and the labour will be less, as he'll be able to do it faster. Might even be able to do it in situ.
This is not a signature.
abs66
Re: Gear box
Unread post by abs66 »
Was there any resolution to this thread as I have an almost identical problem on my 04 xsara Picasso 2.0 diesel. To say I'm panicking would be an understatement!
Sent from my SM-N9005 using Tapatalk
x 1487
Re: Gear box
Picasso HDi uses a different box that is (generally) very tough. Ours ate wheel bearings for fun though, so I would check there first. What are the symptoms?
abs66
Re: Gear box
Pretty much the same as described by the op. Drives fine, no slipping of clutch evident as yet gears seem to go in OK. I noticed it the other night and my first instinct was that I hadn't got it in gear properly (new boots on!) but I had. Then it started making a sort of grinding noise on lifting off the throttle. I'm a little scared of driving it any further but I obviously will have to in order to check things based on ideas people may come up with hence my search through hundreds of different forum posts trying to narrow things down before I'm asked to grab my ankles by a main dealer!! Thanks for replying, I don't feel quite so alone in my search for answers now lol
abs66
Re: Gear box
abs66 wrote:Pretty much the same as described by the op. Drives fine, no slipping of clutch evident as yet gears seem to go in OK. I noticed it the other night and my first instinct was that I hadn't got it in gear properly (new boots on!) but I had. Then it started making a sort of grinding noise on lifting off the throttle. I'm a little scared of driving it any further but I obviously will have to in order to check things based on ideas people may come up with. hence my search through hundreds of different forum posts trying to narrow things down before I'm asked to grab my ankles by a main dealer!! Thanks for replying, I don't feel quite so alone in my search for answers now lol
abs66
Re: Gear box
Sorry about double post, new phone so still learning!
