Peugeot 406 1.9dt R reg engine fault
Dave Burns
Unread post by Dave Burns »
The other sensor is the TDC sensor in the top of the bellhousing.
Note that the ecu drives the tacho on these later 1.9td's, it does not have its own pickup.
The ecu will continue to drive the tacho from either the injector lift sensor or the tdc sensor.
Dave
rich201283
Unread post by rich201283 »
I have unpluged the injector sensor and the tacho still works, I have also unplugged the tdc sensor and the tacho again still works so it again rules the tdc sensor been at fault.
Someone suggested it could be the speed sensor, What do you think?
Dave Burns
There are no other sensors relating to engine speed on this engine.
Dave
alan1701
New User
Re: Peugeot 406 1.9dt R reg engine fault
Unread post by alan1701 »
Hi Rich201283 I have a Peugeot 406 1.9 td to, my car is on the T plate and has developed the same fault that your Peugeot suffered. I am sorry to bother you but I was wondering if you got the issue resolved and if so how because I am at a complete lost as how to repair mine and any input would be very muvh appreciated thanks.
