Looks like the Xm is out of the question as it's just a little bit too much expense, even the 2.5TD engine in mine will cost too much!
I've looked into getting a 12v 2.1TD but this seems to use the MLT? gear box with hydraulic clutch and cable operated box. I'm assured that this WILL fit the BX but in not too confident so will have a deeper look into it, i have however tracked the engine down for about £175 and a BIG intercooler for £100 so with a few other bits i might be able to build something to challenge the BX16v [:D]
I am however now insured on an AX, and since it's only on about 48k (its a N-reg) i intend to put some real miles on it ASAP! Durham and back planned at the weekend for BUSA!
Does anyone know of a 2.1td cheap? some parts of the car attached would be of benefit!
You Wouldn't Believe Me If I Told You!!!
DLM
ACTIVE8
- x 6
