I am an Activaist-v6 and a 2.1Estateerr
elma
x 284
Re: I am an Activa owner...a V6 and I am an addict
Unread post by elma »
Stickyfinger wrote:This is fabric (No4) ?
I'm reasonably certain pipe 5 is metal braid on my cars, will have to check when home.
The more I think about the water absorbance theory the less I believe it.
x 1996
Unread post by Stickyfinger »
New header tank all fitted, RED OAT used and all ports vented of bubbles.
?? Is the little Matrix vent cap the same as a tyre valve cap ?? as mine is in the engine down in a dark place !
Will this happen ?
x 8391
It's a bodge... Better to have an ally one made. It will then last a lifetime.
x 1996
Same thread ??....I have some metal ones
elma
x 284
Stickyfinger wrote:Is the little Matrix vent cap the same as a tyre valve cap?
No, they have an o ring. Tyre valve caps are hit and miss weather they leak or not.
Xantia spare wheels are fitted with the right one, if you have an original spare check it. The caps shorter, rounder and has an o ring inside.
x 1996
Will do....thanks James
I have some metal caps, the type with a valve screwdriver on top....will look at those as well
x 1996
That is done then......thanks for the info.
Aggg,,,,its HOT down there, red arms :)
chinkostu
x 30
Unread post by chinkostu »
the cap needs that little o ring. i replaced mine with a cheap one and it split spewing coolant everywhere!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 1996
It has one inside.... is that not what you meant ?
Standard caps on spares BTW....would PTFA wrap on the threads do the job ?
elma
x 284
If it has an o ring it should be fine.
Citroen and Peugeot sell them for small change anyway.
chinkostu
x 30
Stickyfinger wrote:It has one inside.... is that not what you meant ?
If its got the o ring and it's metal it's probably better, as long as the cap doesn't sieze on (dissimilar metals!)
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 1996
Then maybe I will put a little liquid ptfe on the thread then....I have it for use on the radiators anyway
x 5672
Citroen changed from plastic to metal a few years ago.
I had a plastic one blow off during the MOT and fill the pit where the tester was working with boiling water. He wasn't impressed.
I suspect it wasn't the proper one but a valve cap that had been substituted.
Passed the MOT anyway.
x 1996
LOL....based on that I WILL leave the metal one on then :)
x 1996
Oh good....all OK, no leaks, water holds level, hold temp....so jobs a good'un
BUT
Wine/howl from the left side of the engine.....sounds like a belt tensioner.....but worryingly it does not seem to sound like a aux belt to me (but I hope my inexperience is making me worry to much)
Speed related as it increases in intensity, goes over 2k. Was thinking it was coming from the rear cam at first.
