I think Activa Jim, it's a holiday after all.
The New Forest roads are definitely Activa territory.
Gabriel would be equally happy but I think a few days travel by Activa would be far more fun.
I've just ordered
this very small socket in the hope that I don't have to make one myself. It's 20mm high so potentially a bit short but 6mm longer than my attempt which was unuseably short.
I also ordered a 3.5Bar fuel pressure regulator as recommended by Mandrake, been watching them for a while and the price was good this morning.
Finally I've been looking at adhesive for the headliner. 3m headliner aerosol glue looks to be the choice.
I'm going to get a can next week along with the pump seals.
Still got the never ending list which is below.
Immediately
Seal os headlight.
Gearbox Oil
Sump Leak
Engine Oil
Loom tidying
Repair O/S Fan
Fuel Pressure Regulator
LHM Pump Seals
Alternator Belt
Starter Motor Relay Mod
Headlamp Relay Mod
Saggy Headliner
Rear Washer
Heater matrix connector
Next
Spark Plugs (plus leads, gasket)
Cambox leak
Timing Belt
Front Brakes
Rear Brakes
LHM filter Clean and Change
Center Spheres.
Top Engine Mount
Fuel Filter
Steering (p bushes & drop links probably)
Later
Coil pack
Repair or replace drivers seat
Good Tyres
Outer Spheres
RPM and dipped light bulbs blown
Pollen Filter
Bodywork improvements
The washer pump is pumping so I need to find the blockage or leak.
