dan g
- (Donor 2021)
Re: Citroen and Peugeot Parts Requests
Thanks again
randomandy
Could I have the part number for the standard wheel bolts for a Peugeot 308 (2010 diesel)? The locking wheel nut key is about to give up on life so I think it is time to swap for regular bolts.
-Andy.
-Andy.
- x 6957
The bolts for alloy wheels is part: 9817024580.
However, you could opt for a set of these limpet locking nuts to replace the Peugeot ones. These have no pins that can break off - they use a limpet design and go over the bolt head to remove. They're much more robust. I've used these on my previous X7 after one of my bolts sheared off.
https://www.ebay.co.uk/itm/111365235996 ... SwBslgeEl5
A set of these will be slightly more than 4 standard bolts from Peugeot.
I put some pictures up on my blog here if you want to see how they look:
viewtopic.php?p=659965#p659965
dan g
- (Donor 2021)
Hi folks
5008 rear trailing arm/axle bushes. Can someone help with part no please.
Dan
Dan
- x 6957
Item (2) Part 374894 £109.21 each inc. VAT
dan g
- (Donor 2021)
Hi Marc
The bush where the torsion beam axle pivots/ attaches via cradle to the body
- x 6957
Item (3) is the Rear Crossmember Flexible Joint for Ref:
Part is / was 5131F2, but if these are unavailable they advise part 9814211880 as a replacement.
5131F2: £44.02 each
9814211880: £42.97 each
Of course, these must be replaced in pairs
5131F2: £44.02 each
dan g
- (Donor 2021)
Yes item 3.
Thank you
Thank you
Cit fan 151
- x 4
Re: 2010 C5 3.0 HDI tourer 48k update
For the Adriatic wheels with grey inserts, is it possible to get a colour code (or name) for the grey insert?
- x 6957
Please see the first post here for parts: viewtopic.php?p=685750#p685750Cit fan 151 wrote: 13 Dec 2021, 02:43 For the Adriatic wheels with grey inserts, is it possible to get a colour code (or name) for the grey insert?
DanCD
- (Donor 2021)
Hi Marc,
Can you give me the part number for the valve cover bolts for my Citroen C4 .4 VTi.
Let me know if you need my VIN again.
Cheers,
Dan
Cheers,
Dan
Dan
Huskyxantia
- x 906
Good morning Marc, another busy one for you, have you a parts diagram of the 2.0hdi xsara picasso gear cables and all fixings ive purchased a new set but one of the plastic gromets had broke ! Its gear stick end.
Many thanks again.
Many thanks again.
Husky.
- x 6957
Let me know which items from below Dan:DanCD wrote: 13 Dec 2021, 09:30 Hi Marc,
Cheers,
Dan
- x 6957
Her you go; if you need any part numbers, let me know the item numbers from below:Huskyxantia wrote: 13 Dec 2021, 09:37 Good morning Marc, another busy one for you, have you a parts diagram of the 2.0hdi xsara picasso gear cables and all fixings ive purchased a new set but one of the plastic gromets had broke ! Its gear stick end.
Many thanks again.
Huskyxantia
- x 906
No.9 i need that ... fiddly little plastic snappy easy things lol
Thanks marc
Thanks marc
Husky.
