- x 2341
Enough of this toilet humour!
- x 8125
Don't sink to their level Matt!
- x 1489
daviemck2006
- x 485
If you ask me they are speaking sh1te
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 1072
Let's stop taking the pee....I'm surprised it's not all stainless steel to look like a train toilet, then it would be a proper poop hole
Champion of Where's CitroJim
- x 8400
Huge giggles to all of the above
Highest quality banter
Yesterday morning I had a perfectly functional bathroom...
I went for a most excellent lunch with Mick yesterday, to the Fancott Arms again who both serve the most excellent food in most pleasant surrounds and cope with my rather difficult dietary needs with aplomb. The establishment comes very highly recommended.
The halloumi kebabs were simply delicious as was the vegan Ice Cream to follow. I asked the server if it was lactose, gluten and soya-free? She replied that it was free of everything... Fair enough
It was remarkably good and very much like proper ice cream...
And I came home to find this
The demolition squad had been in! Still, one has to break a few eggs to make an omelette and I know it'll be worth it.
I drove Strawberry to the Fancott yesterday and went armed with my IR thermometer to check her coolant temperatures. Just after a good run it was found to be 88 degrees. Spot on to the thermostat setting. My worries about the cooling fan cut-in temperature were groundless; the fan cuts in a 92 degrees and cuts out at 85 degrees. I'd say that was just about perfect
- x 8400
Bathroom work continues apace and lots of old bodgery is being revealed... The space under the very squeaky and wobbly floor was full of all sorts of old builders and plumber's rubbish!
We had a 'funny' the other day as a direct result of the work: I found I had no hot water in the kitchen following the water going off to remove the old plumbing in the bathroom and plumb in new pipes. The oddity was that although there was no hot water in the kitchen, the downstairs loo had too much - the toilet cistern was being filled with hot water!
Thus bringing a whole new meaning to the term 'hot flush...'
It had us scratching our heads for a bit and in the end we found it was all caused by swapping over hot and cold pipes upstairs.. My kitchen cold is fed directly from the rising main whereas all other cold feeds are via the upstairs boiler plumbing! It was quickly resolved!
Yesterday the old van got a bit of TLC. I planned to replace the front discs and pads but when I looked they really were not that bad despite being a little juddery upon heavy braking. The pads have years of life in them so given my driving style and how much I use the van. I'll do them another time. When I need to, it's a clearly very straightforward job.
Keen eyes will note in the above photos that the mudshield has been removed. This was for me to learn how to do it and give me a view into the area I'll need to access to replace the cambelt and water pump.
In removing the mudshield, a big lump of sound-deadening material fell out
I couldn't work out from where at first until I realised the shield has a piece of it on both sides - fore and aft. Here's the fore nicely in place:
I could see why the aft fell off: there's a big crack and hole in the base of the mudshield right by the pad fixings...
I guess a big stone flicked up and smashed it at some point...
I can't imagine these pads do much so I'm not going to worry about replacing it.
I was surprised at how much muck and rubbish fell out along with the pad when I pulled the mudshield down...
The cambelt will be done as soon as the bathroom is done; currently my working space is very limited due to a fleet of white builder's vans on my drive...
- x 8125
That crack/hole in the mudshield is a classic for repair with the hot staple gun and a piece of suitable plastic for a patch. Ice cream tub lids work well!!
- x 8400
Good thinking Mick
Will vegan ice cream tub lids work? Asking for a friend
- x 8125
Have you got a hot staple gun Jim? I can't remember. If not you could bring it here and we-ll sort it.
- x 1489
Cambelt will be a piece of cake for you with small hands, Jim! You might need some more heft to get the crank bolt out - but they are not that tight. Supposed to be replaced - decent kits come with a new bolt. No real gotchas on these, unlike the 2.0 HDi with the hidden, different sized, bolt down the back!! It's a bit tricky to rotate the crank and wiggle the locking pin (for holding the crank for bolt undoing / tightening only) in over the exhaust single handedly... I've never managed to get the belt back on over the tensioner, but it's easy enough to fit the belt first, then bolt on the tensioner afterwards.
- x 2341
I hot stapled the blue 308 SW front mud shields, they unfortunately didn't fail where I fixed them but fresh locations instead!mickthemaverick wrote: 26 Aug 2026, 10:58 That crack/hole in the mudshield is a classic for repair with the hot staple gun and a piece of suitable plastic for a patch. Ice cream tub lids work well!!![]()
This was hot staple then reinforced with a "bead" of hot glue gun over the top to spread the load a bit.
Arch liner very brittle. They are by far the flimsiest arch liners I've come across, without doubt I'd say the 406 Coupe's plastic liners are much better condition despite being more than twice the age!
Bought a new aftermarket liner (Autodoc, about £25?) very thin but at least flexible and thin, rather then brittle and thin!
Had filthy (and unclear if ever did anything meaningful!) "sound deadening" pads on the back just like yours Jim. New one didn't have anything at all.
- x 8125
On my first C5 I had them splitting and no hot staples back then. I actually 'Wallpapered' the inside of the liners with good old blue tarpaulin and spray on upholstery glue, Copydex I believe I used. Repaired and reinforced at the same time!
- x 2341
Ha ha, good old Copydex - am sure it's good stuff but I detest the smell of it! (Assuming the spray on stuff smells as foul as the brush on stuff)
You might have better luck than me repairing them - I did it as much as for a bit of practice with the hot stapler as much as anything.
Incidentally - the new (to me) 308 front arch liners are equally mangled, so they've been hot stapled too (stupidity repeating same experiment, expecting a different result, but hey ho!)
- x 2341
Gosh those C5 sure have big arches!mickthemaverick wrote: 26 Aug 2026, 21:43 On my first C5 I had them splitting and no hot staples back then. I actually 'Wallpapered' the inside of the liners with good old blue tarpaulin ...
