Huskyxantia
x 928
Unread post by Huskyxantia »
180 ! Windows down then lol least its free
:-D
x 8163
I sense a bit of profiteering there!! SWMBO had hers done at the Main Dealer in May and it was £149 including a new valve on the test line!! :)
x 5679
Had mine done at the garage where I bought the car for £50, he only charged for the gas.
Had my last C5 done a few years ago. £120. Lasted a month :(
Pror to that had a mobile bloke come and do both my C5 (not the same one) and my son's 306.
£100 for the pair of them.
x 8440
I checked and around here, it's the going rate wherever you go... If it's doesn't last I won't be having it done again unless any leaks are easily resolved.
Speaking of resolved, with my GF now back home and OK, I could get on with Bluebell...
The crank oil seal replacement went very smoothly :) My rattle-gun made short work of the (tight) crank sprocket bolt and the seal flange did not even need my special puller to remove it..
The old seal came out easily using the old screw trick...
All cleaned up..
New seal in...
And my own patent method to torque up the crank bolt to 81 ft lbs :)
Sadly, it was not so good with the alternator... The new brushes have made no difference so it looks like the regulator module is unhappy :( I can get a new regulator from our German friends for a reasonable sum so I'll get one ordered in along with the cambelt kit and front discs and pads I need for my van...
Huskyxantia
x 928
Nice set up in the last photo Jim , once you get the other parts you need your all sorted then. You do a great job looking after your fave 2 little citroens
:-D
x 2367
Unread post by MattBLancs »
Good work Jim, bad luck on the alternator - nevermind it was worth a shot and looked as though it was the issue.
Is it a big jump from rectifier to full alternator? It'd get you refreshed bearings etc at the same time :)
x 8163
It may be worth asking the company I got the MX3 alternator from in April. They were excellent as is the product: sales@startermotor-alternator-store.co.uk :)
x 8440
Huskyxantia wrote: 04 Jul 2026, 08:08 You do a great job looking after your fave 2 little citroens
Thanks Husky, I try my best :)
MattBLancs wrote: 04 Jul 2026, 09:42 Good work Jim, bad luck on the alternator - nevermind it was worth a shot and looked as though it was the issue.
Indeed, Matt. Absolutely worth risking a fiver on a set of brushes :) And, at least I have a spare set now....
mickthemaverick wrote: 04 Jul 2026, 09:54 It may be worth asking the company I got the MX3 alternator from in April.
Thanks Mick :)
Huskyxantia
x 928
How often do you get to if you do show the cars at any shows? Plus if so , how do you go about it
:-D
x 8440
Huskyxantia wrote: 05 Jul 2026, 07:47 How often do you get to if you do show the cars at any shows? Plus if so , how do you go about it
Rarely, usually only at Citroen rallies I can easily get to. I won't be at the CCC National this year as I'm instead going to stay with my youngest daughter for a few days. I'll be travelling by train to that one and just bought my Senior Railcard!
I do occasionally go to local shows and on Sunday I went to our local Newport Pagnell Carnival show. Literally within walking distance for me!!!
I'll shortly post in the appropriate thread. There was a lot of very tasty cars there but sadly no French...
Currently on holiday :)
Usual place. Back home for a few days :cool:
It was good to have aircon working again in the van on the journey down here. Travelling yesterday morning was a bizarre experience. For a Monday, the roads were deserted - almost to Covid lockdown levels. Amazing. Commuter train travel was down 26% according to the news :shock:
I just wish my caravan had aircon!
x 8163
Although I know you love this week's weather Jim, I think you may be better off sleeping under the caravan than inside with no aircon :-D
x 8440
mickthemaverick wrote: 07 Jul 2026, 06:51 Although I know you love this week's weather Jim, I think you may be better off sleeping under the caravan than inside with no aircon :-D
:lol: :lol: Good plan Mick!
Actually, there's a good breeze coming in from the Atlantic and straight up the channel and it's moderating the temperature quite nicely :-D
x 5679
CitroJim wrote: 07 Jul 2026, 06:30 Image
That's an unusual perspective Jim, looks as though the sea is higher than the wall, maybe due to the shape of the rounded off top of the wall.
x 2367
Ah, excellent. When the dust settles on my car situation, looking into a regas on the Grey 308 is on my list.
Thanks to those posting prices, good to know the rought ballpark
(I thought it was £30-£40 job!! :eek1: )
Fantastic wasn't it! Normal M6 conditions resumed again today
x 8440
Yesterday I submitted a big order to AutoDoc... Cambelt kit and new front brake discs and pads along with filters and other small items for the van and a new regulator for Bluebell's alternator. I also took a chance on a new alternator - just in case. If not needed it's always good to have a shelf spare.
The van definitely needs new front brakes - they're getting a bit juddery under heavy braking...
I had a good journey home from the seaside on Friday. Due to a road closure on the A39 I had to travel a completely different route via Taunton and eventually the A303 and A34. It worked well and happily I did not loose every bit of any will I still had to live negotiating the Poxford Bottleneck. Remarkably, it was moving quite well and I did not experience any congestion until I encountered extensive roadworks in Bicester...
I got home in plenty of time to visit the chemist and attend a doctor's appointment :)
It's not my favoured route as it's not good for a stop at Alasdair's. It would be quite a deviation to do so...
