x 8140
Following Steve's comments there, maybe you could utilise your existing Longcase Clock Jim?
Or maybe a suitable addition to blend in with your collection
https://www.ebay.co.uk/itm/236882173606
x 8421
myglaren wrote: 21 Jun 2026, 10:30 Or gut a grandfather clock :yikes:
That's fighting talk :twisted:
myglaren wrote: 21 Jun 2026, 10:30 Do you have a pair of tongs to wipe the surface water off, makes a big difference in the drying time. Most just use two fingers of course, not always the best method.
I did until the one time they scratched a negative - a trick they seem to be very prone to :evil: Nowadays I use my nitrile gloved fingers. To help drying in this very hard water area I always use a drop of wetting agent in demin. water for the final rinse with black and white and proper C41 stabiliser in demin. water for colour.
For now my shower cubicle is doing a good job as a drying cabinet :D
myglaren wrote: 21 Jun 2026, 10:30 was unable to find one but they used a 'paddle wheel' system, rotating back and forth in the various chemical baths, the 'bath' part would rotate through 90° and tip the chemical out, return to place and be filled with water or the next chemical in sequence, up to 60 10x8" sheet films at a time.
All appear to accept film at one end and spit it out finished at the other now.
Is that what is called 'Dip and Dunk' Steve? I've seen reference to it in the Ilford developer data sheets...
mickthemaverick wrote: 21 Jun 2026, 11:13
I'd fill that with a clock Mick ;)
Yesterday I took a trip to the Citroen Car Club D Section rally at Little Horwood. A lovely day for it :D
As expected, there were lots of Ds there but unusually and disappointingly, very few of any other model. Mine the only AX along with just one BX, one CX and one XM along with lots of modern tat.
Here's Strawberry with a car whose numbers at the rally were double that of the AX...
Photos to follow when I've processed the films ;) The above was the only photo I took on my phone...
x 5672
The 'dip and dunk' is in static tanks in series, with a water bath around them to regulate the temperature. Hold about 15L and the film wound into spirals, like your developing tank but stainless steel, that then go in a stainless basket. Sheet film clipped into frames and a rack. As the name implies, the film is lifted out at regular intervals, constant the first minute then usually every 15~30".
Or a machine on a similar principle but much larger tanks. about 10' high, tanks about 5' deep, individually temperature regulated and each with a pump and filter to circulate the chemical in it.
Films hung on clips in frames as in your drying cabinet with weights on the bottom of each and sheet film in frames. the films lifted, advanced a few inches and lowered into the bath, or the next bath, on a timer. The size of the bath dependent on the time needed to have the film in it. Then into the dryer where the frames were just advanced, no lift and drop as not necessary. I did try and find a photo.
We toured Germany looking for a suitable one for us, visited Hostert, the most well known manufacturer, and another in Bremen who's name escapes me but a very impressive modern machine, lots of electronics and very expensive.
A Hostert B&W machine.
Settled on one from Wainco in St. Neots.
I brought a lorry over, left it at their factory and their joiners built the machine into the lorry overnight. The MD dropped me at a hotel and picked me up the following morning in his Triumph Stag, which he seemed to be very proud of.
Drove it back to Sweden and an engineer flew over a couple of days later to construct and commission it in a lab we built for it. It was huge, needed about 12' height clearance and was around 30' long, half in a darkroom and the drying section in the light.
x 8421
Thanks for that Steve :D Very interesting :cool:
Yesterday I had a play with Gemini AI to see how well it could colourise this black and white image of Strawberry and one of her friends.
First attempt.. I simply asked Gemini to colourise and nothing more...
:shock: I guess she must be cold :lol: Spot all the other mistakes too...
Then I tried again with this directive:
Please colourise the image. The car (Citroen AX) in the foreground should be red with black bumpers and amber front indicator lenses. The other car (Citroen Xantia) should be silver. Do not alter any background details in any way. Thank you.
That's better!
x 1469
Unread post by xantia_v6 »
Interesting that on the second attempt it got the plate colour correct on the Xantia.
x 2356
Unread post by MattBLancs »
Err, did you clock the "quadruple chevrons" !?
Spoiler: show
picture zoomed in:
Double vision
Double vision
x 8421
xantia_v6 wrote: 23 Jun 2026, 05:49 Interesting that on the second attempt it got the plate colour correct on the Xantia.
Yes, I noticed that Mike... Shocked it got it wrong first time :twisted:
MattBLancs wrote: 23 Jun 2026, 06:49 Err, did you clock the "quadruple chevrons" !?
That and also, Series 2 clear indicator lenses...
I do wonder if AI was 'aware' I also have a blue AX with the chevrons in the middle of the bonnet and used that knowledge... If it's that clever I've have though it would have read the number plate to get the colour right first time...
Worst of all perhaps is the appearance of a big building that does not actually exist in the car park :roll: :o :lol:
Yesterday, I tried colourising another black and white picture of the girls and when asked to colourise with a directive 'do not alter anything in the background' Gemini did and made a terrible job of the whole thing. All my girls were changed beyond recognition and things appeared in the background. Horrible :twisted:
When I simply asked Gemini to colourise with no directives at all it did a prefect job :)
x 2356
Ha ha, I completely missed the photo bombing building!
I guessed the double badges was "show AI ten million AX pictures" and it learns (MK1?) offset and (MK2?) central grille badge locations so gives you both at the same time!
x 8421
MattBLancs wrote: 24 Jun 2026, 18:32 Ha ha, I completely missed the photo bombing building!
Amazing how things can hide in plain sight...
MattBLancs wrote: 24 Jun 2026, 18:32 I guessed the double badges was "show AI ten million AX pictures" and it learns (MK1?) offset and (MK2?) central grille badge locations so gives you both at the same time!
AI does like to give you the best of both :lol:
As my workshop/garage was about the coolest place yesterday, I got stuck into Bluebell's alternator..
It's so annoying when what's normally a 10 minute job to remove the alternator is extended by several more minutes because the engine needs to be jacked up by slightly less than a gnat's cock to free the top bolt :twisted:
And you find a slightly burred nut and stud on the engine mount needing the attention of a tap and die...
And it's observed that the timing side crank oil seal is leaking a little :twisted:
Once the alternator was off, I removed the regulator assembly after a short battle with two very tight slotted head screws...
The slip rings are in excellent condition :)
Not bad for what I'm certain is Bluebell's original alternator. I found it's covered in 1990 date codes.
As expected, the brushes are worn out...
A new oil seal and a set of brushes are on order. The regulator has been prepared for their replacement and later today I'll start work on preparing the engine for the new oil seal. Happily, the cambelt is not contaminated so although it has to be removed to replace the seal, it can be reused...
I'll also do a coolant change whilst I'm at it...
x 3565
CitroJim wrote: 25 Jun 2026, 05:32
A bit different to down here - there weren't any coolest places.... it was just different intensities of unbearable.
A bit like sex in a campsite.....
..... f**king intense :?
John Pankhurst
(Donor 2026)
x 44
Unread post by John Pankhurst »
Twas a tad warm in my garage too
I was in there for ten minutes and could wring me shirt out afterwards
x 8421
bobins wrote: 25 Jun 2026, 06:52
:lol: :lol: :lol: Love that!!! I did giggle :lol:
I must admit to being quite content in this weather. It just reminds me of the years I lived and worked overseas in hot corners of the world and largely without the benefit of aircon.
Plenty of my working life was spent outdoors during high summer in aerial fields...
I got well acclimatised and it seems it never left me; I struggle far more with cold - even quite mild cold I find intolerable. The only legacy I have is skin cancer but that is my own fault for being careless with the use of suncream.
John Pankhurst wrote: 25 Jun 2026, 10:25 Twas a tad warm in my garage too
That's proper toasty John! I've not measured the temperature my workshop although I happily spent more time in there yesterday working on Bluebell :)
I pulled off the timing covers in preparation to remove the cambelt. Oil leak confirmed...
The cambelt is now off and all is nicely cleaned up ready ready for the new bits to be fitted...
After that, I spent time tidying up the garden and mowing the lawn... I was not the only mad dog out in the midday sun. As soon as my mower stopped I heard another start up nearby...
In deference to the sun, I did apply plenty of sunscreen and wore a hat...
x 8140
You brute!! You mowed the grass in this heat? Poor grass, losing its protection from the evil yellow ball!! One cricket strip on the way!! :-D
x 8421
mickthemaverick wrote: 26 Jun 2026, 06:07 You brute!! You mowed the grass in this heat? Poor grass, losing its protection from the evil yellow ball!! One cricket strip on the way!! :-D
:lol: :lol:
PaulC5
x 697
Unread post by PaulC5 »
I wonder if whether we like the heat or not is a bit determined where our ancestors came from. If Scandinavian with the Vikings or Mediterranean with the Romans. Once above low to mid twenties it is a bit much for me, when younger my hair was fair so I may originate in the north. Currently on hormone therapy injections for prostate cancer so having sweats twice an hour which does not help.
Our plastics/tins/glass bin has just been emptied and I gave the bin men (if still allowed to say that) a big bottle of water and some ice creams, much appreciated as it is about 33°C outside in the shade. As council workers you might think they would not have to work when too hot.
