Xantia 1.9 TD Oil Change
soupy_sam
Unread post by soupy_sam »
When I change the oil in my Xantia 1.9 TD is there a washer on the sump plug that needs changing? If so what is the size of it?
np
Unread post by np »
Yes there is.A small copper washer.Dont know the size.I just ask for 1 when i get my service bits.Cost 50p at the weekend.When you tighten up the bolt,it squashes the washer,making it seal.Hence the need for a new one.Although i`ve re-used them in the past with no leaks from the sump bolt.
Jon
Unread post by Jon »
Its a 14mm crushable copper washer.
soupy_sam
Thanks guys purchased washer and all was well[:D]
