Had the new car for two weeks now and love it to bits.
One niggling problem has surfaced, however: the headlamps are badly adjusted; LHS is too low, RHS is pointing too far left leaving a big shadow in the road on main beam.
I lifted the bonnet t'other day and had a fish about, but cannot for the life of me see how to adjust the damn things. It should be pointed out, however, that I have a degree in overlooking the bleeding obvious!
Anyone care to offer advice, please?
Headlamp adjustment '01 Xantia
Kowalski
The MKI headlights have adjusters that can be adjusted with a long 7mm allen key, the later MKIs can also be adjusted with a philips screwdrivers. On the MKI the front crossmember has two holes in it above and towards the back of the headlights, sticking your allen key / screwdriver in these adjusts, one does up/down the other left right.
Yours is a MKII so it could be completely different or it could be similar. Headlight alignment on Xantia's doesn't go out of adjustment on Xantias unless their front end takes a knock, and then they're very prone to it.
littleredrooster
bernie
littleredrooster
littleredrooster
