Biggest Wheels on a Citroen ZX?
robsons
Unread post by robsons »
Check out the photos and those TSW's are 195 x 50 x15"
Basically the max you can put under the std arches (more on 16V) - If you load your suspension on the corners and get the "rear wheel steering" to do it's bit you can get the 195s to rub too - Stick to 185x55x15's to be safe if you want to use 15"
tomsheppard
Unread post by tomsheppard »
WHY?
Robsons is right. You'll lose ride comfort and grip in the wet anyway.
Do you honestly think that Citroen didn't know how to design a chassis?
