mystery wires
maddave
mystery wires
Unread post by maddave »
Hello, just changed both my headlamps as the refelctors had almost dissapered in the old ones. Amzing improvement and I can actually see the beams on the road now.
One thing I did notice though was that there are two wires on each headlamp that dont go to anything. They are green/yello and yellow(I think), and have spade connectors on them. They are tapped to the main beam headlamp wires. Any ideas what they are for and can I wire them into another bulb some how to get even better lights!!?
The car is a 1993 405 GL, manually adjustable lights. Ithink they may be for the newer lights which had another bulb in, rather than my two. Yes?
Cheers,
David.
PowerLee
Unread post by PowerLee »
Hi
Green / Yellow is going to be an earth wire.
I think the other wire is gonna be a thick white one with a black spade connection on.
If yes then this is for the twin vision headlamps fitted to the sporty & higher spec 405s.
Your GL will have the single vision headlamps with only 1 x dipped / main beam H4 bulb in.
The twin vision has a seperate H1 main beam bulb as well as the H4.
