My 1997 xantia 1.9TD has never started well, when i got it about a year ago i replace the glow plugs for Beru ones (it had a set of dodgy bosche ones in it) which helped the usual symptoms: clouds of white smoke, firing on less than 4 cylinders, very lumpy idle, all sorted by waiting for about 20 seconds anr evving lightly. Eventually I tried to trace it to an air leak and found the final injectors little nipple stop-end thingummy had split, nice citroen garage gave me one for free and things got much much better, inf act things have been perfect ever since i did that about 5 months ago..
Now i drove about 60 miles over saturday and the car sat all day sunday, came to start it this morning and boy did it chug [:(] worst its ever been, took about 3 or 4 minutes of gentle revving to clear it, and even then it was still mis firing every now and again at idle for another new minutes.
I'm thinking air leak again, but this time quite a bad one, but i ont have a clue where to look and the most likely culprits (other than the injector excess fuel pipes) if i prime the handbulb it doesnt even stay hard long enough for me to get in the car and start her up to see if it helps! Theres no obvious squeeling noise or bubbling in the engine bay when i prime the bulb (how i found the last leak) as far as i can tell the fuel filters lid is on tight (though ill check the seal tonight when i have access to a socket set) Where else do i need to pay attention to, that engine is like a labyrinth....
Also worth noting, whereas when i first got it if you got it going, it would then take the (seems about usual) 8 odd hours before it would be effected again. Well i just started it during my lunch break, 4 hours later and it was just as bad as this morning [xx(]
Im desperate here, i can see me coming to it soon and it not starting at all.. which would be a nightmare add infinitum
thanks guys [:I]
