Anyone ever had a go at fixing one of these?
My fuel gauge swings between empty and 3/4, I've just put £30 of diesel in so 3/4 is probably about right, but the bloody gauge just sort of flickers about for most of the time, sometime even on a straight road!
The sender unit in the BX appears to be a cannister arrangement with some sort of coil inside, have not had time for a good lock at it as yet, does not seem to have plastic float arrangement like the ZX had.
Perhaps I just need to buy a new one, but, at £50.12 + vat........
BX Tank Sender
Richard Gallagher
The chances are that it is not the gauge or sender unit but the voltage stabiliser, a small sealed box usually found somewhere on the instrument panel. The purpose of this unit is to slow down the movement of the gauge needle, as the float moves up and down with the movement of the fuel.
I'm not sure about BX's but most cars do have such a device.
AndersDK
Hi Jon -
The sender unit is a dead simple slide potientiometer. My personal experience is that the 3pin multiplug fails, or the ribbon cable termination in the multiplug fails (corrosion).
The connections are as follows :
pin1 : earth feed
pin2 : lo (earth) side of gauge (resistor element)
pin3 : lo (earth) side of empty lamp (earth switch)
You'll find the plug under the center most large plastic cap under the rear seat squab.
AFAIR the earth feed point is on the X-member under front seats - somewhere near the center panel under the carpets. Could be a corrosion problem here too.
pin1 : earth feed
AndersDK
jeremy
uhn113x
- x 3
Voltage stabilisers (not present on BX) are nothing to do with damping the fuel gauge, but are to supply a regulated voltage (usually 10) to the instruments, which otherwise would receive a supply of anything from 12 to 14.8 volts, affecting the readings (which it does on a BX!)
The fuel gauge is usually damped by working on the hot wire or bimetallic strip principle, or is magnetically damped.
tomsheppard
You can put in a 10 volt regulator chip for this but it isn't worth it. They do swing around and act as inclinometers so the best way to interpret them is as an indicator, not an instrument.
It works like this:
fill tank.
At 130 miles needle moves off full stop (You have used the fuel in the extra tank)
At 330 miles, the needle is vertical and showing 1/3 used. No, it's 60%.
at 550 miles, The evil eye begins to flash
at 630 miles, FILL UP!
It works like this:
fill tank.
G4EIY
Hi,
I can concur that the swinging neadle is usually a bad connection to the sender located under the back seat.
Also the sender is AFAIR, a float that wipes on a glass fibre printed circuit board, and the bottom part of the printed circuit is prone to be damaged, just disapears, this causing the gauge to drop to zero at low tank fuel levels.
uhn113x
- x 3
Taking this a bit further - on an A-Series:
Reads 1/2 on left turn - nearly empty
Reads empty on right turn - just under 1/2 full (or 1/2 empty if you are a pessimist)
For a DS, transpose 'left' and 'right'
One day I will see what sticking a 500mfd electrolytic across the gauge will do.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tomsheppard</i>
It works like this:
fill tank.
It works like this:
fill tank.
tomsheppard
Jon
Thanks folks, will attend to the sender/connections this weekend, Vanny is sending down a replacement unit in case thats the problem.
Todays unusual fault appears to be with the supplementary fuel tank. Upon filling up this morning, lots of precious diesel started pouring out onto the ground. There's some problem with the supplementary tank , its soaking wet. I also spied that the bracket that should secure the thing is gone, replaced by some rope. Oddly neither the MOT tester or I spotted that before!
G4EIY
uhn113x
- x 3
it will increase the capacitance- not make the tank any bigger!
Thought it may stop the (moving-iron) movement bouncing as much - may need to be biggerm as total R in circuit is low. I saw a fuel gauge off one of those 50cc 'hairdryer' mopeds once, that had no return spring, and the moving iron sat in a pot of silicon goop, so it retained its reading when the supply was switched off.
