cleaning / dismantling height correctors
bernie
Unread post by bernie »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by uhn113x</i>
Hi Anders
No, I meant the stack of (10?) steel discs with tiny holes, assembled with spacers, that you remove by unscrewing the brass plug with 2 flats, in the end of the body, accessible after removing one of the steel discs.
<b>Excerpt from text I did:</b>
<i>Looking straight at one end of the body, you will see the damper port, with a plug screwed into it to retain the damper discs. This plug needs a tool making to remove it – select a piece of steel rod (nail?) slightly smaller in diameter, and saw a slot in it that will go over the raised central part of the plug to unscrew it – it will not be too tight.
Carefully tap out the discs and spacers – all discs (10 if I recall correctly) are the same, but there is one larger spacer. Discs have minute central holes where dirt accumulates.</i>
I am finding that the white plastic plug just spins round as if it is held in by a lip. Does not appear to be threaded at all.
Any ideas?
uhn113x
x 3
Unread post by uhn113x »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by bernie</i>
Hi Anders
Any ideas?
Bernie
White plastic plug? Is this in the end of the damper stack? They must have changed the design, then. What shape is it? Any chance of a pic?
bernie
Yes Mike I think a totally different design.
I'll try to get up some photos
