Brakes
Brakes
I have a 2001 mercury sable,front brakes just replaced. Still having problems. When pressing pedal it goes to floor at times and dont stop. Also once when pressed it whent to floor and jerked hard to right . Can anyone give me some sugestions?[?][:(]
Difficult to understand why one would need to replace brakes in a 2001 car. Generally, steering anomolies under braking indicate worn steering/suspension, which is not plausible in 2001 car. Look at the workmanship on the brakes ; are the pads all seated properly ? Can there be uneven pressure distribution between the wheel cylinders? Or is a wheel cylinder siezed or leaking?
