Clio wiper problem
This is the Forum for all your Renault Technical Questions, Problems or Advice.
dvhttn
Clio wiper problem
Unread post by dvhttn »
Hi,
We have a Clio 1.2 Oasis, 1996 (N reg). Made the mistake of trying the windscreen wipers when they were frozen to the screen - thought they were free. Since then they wil, not stop in the correct position. They stop when you switch them off - no matter where they are on the screen.
Has anyone else seen this and, if so, how did you fix it?
reblack68
Unread post by reblack68 »
You've probably blown a fuse. Renault wipers will park with the ignition off so the park function must be protected by a different fuse from the wiping function.
I think a look through the fusebox will solve your problem. Let us know if that works or not.
clio_laguna
Unread post by clio_laguna »
they have 2 fuse on the wipers check both
