I have a 605 SVDT and the temp gauge does not work and the electric fan comes on as soon as i start the car and runs constantly until i stop the engine.Before i replace both switches (temp one looks fairly new)is there anything else i should check first?
Any help appreciated.
605 electric fan
hariaran
chummy64,
i drive a 605 SVi. the fans on mine come on immediately if the a/c is switched on and keeps on running until engine is stopped. normally without the a/c they come on only when when the temperature hits close to 90deg. you might want to check the relays and the fan motor as well.
hope this helps.
cheers,
hari
hope this helps.
cheers,
hari
