Xsara
np
Xsara
Unread post by np »
Just like to share my thoughts on the xsara.I had 1 on loan last week while my car was being fixed.Dont mean to upset any owners out there.
Xsara W 00,1.4, forte i think(only 1.4 badge)
Good points,[:)]
C/control,
screamer of an engine,
4 wheels,
better than walking.
Bad points,[:(]
Poor mpg,poor rear visabilaty,low rent interior,poor build qulity,big panel gaps on all joins,useless stereo,center dash & controls seem to be angled for left hand drive,rough ride,silver gear knob worn white.
I know its time is nearly up but...
Zx was much better,Xantia too.Saxo better as well,and that was a cheaper car.Is this why you dont see alot of Xsaras???
Agree[^] or disagree[V]?...
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
[quote]<i>Originally posted by np</i>
My daughter has an HDI -= and she loves it! I don't mind it either - but I like my Xantia better.
Travel through Spain and you'll realize that the Xsara is probably their most popular Citroen.
Stuart McB
Unread post by Stuart McB »
As a Xsara owner I must say the the Xsara is more evolutionary than revolutionary.
VisaGTi16v
Unread post by VisaGTi16v »
well it was the same chassis as the zx :)
ralph
Unread post by ralph »
I'd say the Xsara is typical French - major components are rock solid, the rest will gradually fall apart.
Had mine for 2 and a half years.
Rev counter packed in (common XUD problem),
Power steering pump went at 100,000 miles, (pulley bearings gave up)
Exterior door handles are weak, passenger side now unreliable (fix that when I can't get in)
Front seats lack support (mine's an LX)
Airbag warning lights occasionally come on for no reason
Slight rust underneath boot floor.
Paint easily scratches and marked (dark blue)
Apart from that, no bother. 50mpg easy on a long run. Quite rapid, comfortable, but not a screamer around corners.
Looked after it should last a long time, and it's easy to work on.
Poor rear visability has an upside - you're not on show when you cut other drivers up.
np
Unread post by np »
Over all,it was ok.It was better than walking!It also had high miles,& as a spare garage car,been thrashed by every one.Maybe i expected more from a 3 yr old car.
xsaraboy
Unread post by xsaraboy »
my xsara vtr has been fine for 2.5 years only a few niggly problems which have been sorted
