Dead AX
lara
Dead AX
Unread post by lara »
My friends Ax is dead, battery is totally flat, have jump started it and now starts fine. Fan belt seems all right, Battery and alternater were checked recently, charging properly, no lights left on. Any ideas?
thanks Lara
lara stowers
Joolz
Unread post by Joolz »
I had a similar problem with a Ford Escort a few years ago. On that occassion the battery wasn't firmly located and would shift slightly. It would touch the bonnet hinge (when closed) and directly short out causing the battery to flatten and the car to die instantly. Open the bonnet and the problem was not apparent. I don't know the layout of an AX so this might be no use at all!
Joolz
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
A duff battery maybe?????? My three year old Xantia's battery suddenly gave up, fifteen minutes after a 200 mile drive.
hardmanm
Unread post by hardmanm »
Unfortunately modern batteries tend to suddenly die, usually brought on by a cold snap, producing exactly the symptoms you describe, this can happen when they are as young as 2-3 years. It is probably worth checking that nothing is discharging the battery, it you can't find anything resign yourself to getting a new battery.
