A simple Xantia front bumber Q?
Stempy
Unread post by Stempy »
That is, how easy/difficult is it to remove the front bumber on a facelift Xantia? I want to replace the blown fog light bulbs and trace the headlamp washer fault but don't want to spend two days doing it[:)]
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Which side fog lamp do you want to do? Without removing the bumper, I believe the n/s is easier to reach than the o/s. However, by taking off the wheel arch liner and undoing the bolts on the washer reservoir, if your hand is not too big, you can change a bulb.
Stempy
Both sides have gone and also the headlamp washer pump isn't working so I think unfortunately bumber off is the only way.
