Bubbles in LHM reservoir
ohms69
AndersDK
Brake doseur ?
1 drop pr second ?
This has nothing to do with a fast ticker leak problem !
To make it clear :
If the brake doseur should be the cause of fast ticking/rattling - then it must have <font color="red"><i>flow</i></font id="red">, even pressure - not just some fast dribbling ! - no way buddy !
It can only be the PR - or the FDV - causing this problem.
Since the PR does in fact emits a tick - this indicates the pump can deliver a pressure of more than 170bar - which is the cut-out pressure of the PR valve emitting the tick. This then by far excludes the pump.
1 drop pr second ?
To make it clear :
ghostrider
Just a minor point, but is it conceivable that one of the new sheres is faulty? It has happened to me before and I've rushed off checking everything under the sun before finding that a new sphere was faulty, shouldn't happen I know but S**T happens:-(
Pete
________
Washington Medical Marijuana Dispensaries
Pete
________
AndersDK
ohms69
AndersDK
AndersDK
ohms69
