Its a 92 AX GTI[8D]
heres wot happened : was drivin home from work yesterday,,, hit 80 odd in thrid then 4th then 5th,, slowed down to 60 ish in 5th and the car starts rumbling and shakin and sounds all spluttery and didnt wanna pull - the sound that happened when it messed up was like as tho sumthin got sucked up or a blocking-ish sound,, real hard to describe,,, i thought i had a flat tyre at 1st i should be so lucky!
Now whe he tries to start it chugs and chugs,,,, and he got it to start once,,, after pumpin the accelerator,, then it sounded rough like a motorbike but worse ,, then i just turned it off,, in the enginebay , could smell petrol/gas but there is oil on it anyway from the leakin rocker cover gasket,,, so i dont know what to make of the smell...
