HDi & XUD Differences
rossd
Unread post by rossd »
Was just browsing through the Electronic parts catalogue and noticed that the HDi (DW10) is not that much different from the XUD (XUD9TE). Looking at the two engines in the flesh, the head is obviously different, the block looks similar, but the Parts CD confirms that the HDi shares it the bottom end with the old XUD, its identical! They have the same crankshaft, connecting rods, big ends, even down to the bolts!
So the DW series is just an XUD with direct injection!
Jon
Unread post by Jon »
The XUD crank is used in the 1868cc DW8 normally aspirated diesel. (501H1). The DW8 is really an XUD with a bit of a makeover!
However the 1997cc HDi uses a different crankshafts, 501E2 without rollers, or 501E3 with.
XUD, DW8 and HDI do all use the same crank bearings.
Why change a good thing!!! XUD diesel been going strong for 20 years now, and its rare to ever knock out the bottom end on one.
[:D]
rossd
Odd, my parts CD says that the later XUD9TE also uses the 501E2 crankshaft.
The non turbo XUD and DW8 used the 501H1.
Edit: Sorry, when I said XUD in the first post I meant the turbo version, eg XUD9TE. OOPS!
Jon
Sorry, you are correct in that the XUD9TE uses the 501E2.
When I looked at this earlier, I chose a vehicle that had used an XUD7, an XUD9, a DW8 and an HDi, that vehicle being of course the Berlingo. There was of course no XUD9TE Berlingo, thats why I didn't spot that this engine supplies the HDi with basically its complete bottom end!!!
Kowalski
Unread post by Kowalski »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Jon</i>
The XUD diesel bottom end is so heavy that when the pistons and valves have a fight, it breaks the camshaft instead...
ekjdm14
x 281
Re: HDi & XUD Differences
Unread post by ekjdm14 »
OK thread necromancy time, only took me 20 years to get to this one!
So are the DW10 and XUD9TE bottom ends literally the same but different? Have read a few things about mechanical injection & HDi and this coupled with our latest purchase got the cogs ticking.
We're picking up a rolling '96 ZX minus engine/box & I've had a DW10/gearbox out of a 406 sat under a tarp for years too. I understand the pistons are different on the DW10 and won't work with the IDI XUD head, but not sure if anyone's found a suitable piston yet. From what I can gather the DW10 bore is only 2mm larger than the XUD. Compression heights are within 0.05mm the only stalling point I can think of is the HDi has the bowl, being a DI type.
I'm wondering exactly how much this would affect compression if mated directly to an XUD head (using HDi gasket) and also (mainly) if anyone knows of an existing 85mm IDI piston with similar compression height, matching pin diameter etc.
Not trying to reinvent the wheel here, just looking to utilise parts I have laying around if at all possible. Still searching out a real XUD as a preference, but if all I can come up with is the head then I'd love to take on the challenge of an "HIDi"
'95 Xantia LX 1.9D-auto, Black, 123k
'96 ZX SX 1.9TD, White, 90k
'87 Nissan Sunny 1.3L, 63k
'12 Mini freebie project
