Citroen AX 14D Gear Linkage. There is loaaaads of play in the linkage when it's in gear. To say it's sloppy would be an understatement! I've had a quick look and most of the problem is due to play in the upper selector linkage that goes into the gearbox. I can't see how to get it off, is it a gear box strip job to sort this one out?? Opinions on this anyone.
92 AX 14D 75K
(93 Xantia TD 177K)
AX Gear Linkage
AndersDK
Ya mean the selector rod protruding from the box has this large play ?
IIRC this rod is a simple bend with ball end for gear linkage connection - it sounds indeed fiddly to replace any worn bushings here.
I'd be definate it's the rod before deciding any repairs. The ball links can certainly be worn & very sloppy - but easy to replace.
Since your AX is a 14 model - it's the same basic engine & box found in the BX14 '88 on - which would be the type K1G engine & type 2CA gearbox.
These are easy to find info/documentation on from the web.
KAD
