height corrector Xantia 1.9td
ned
Unread post by ned »
just changed rear height corrector on my Xantia
car seems rather bumpy and seems higher than normal
Dave Burns
Unread post by Dave Burns »
After such work the height needs to be reset, do this by loosening and turning the ball end clamp on the anti roll bar, to lower the height turn the clamp so the top of it turns towards the rear.
Only do this after making sure the links and levers move without stiction, if they move and stick or are stiff to move they need freeing off.
Make sure you can't get trapped while doing this, the body can come down very quickly.
Dave
ned
thanks for advice dave will give what you suggest a try later today
BonceChops
Unread post by BonceChops »
the body can come down very very quickly
