OK - I chnaged the engine oil and filter today and whilst it was up on the lift had a good poke around to familiarise myself.
I found a couple of drips forming on the pressure regulator, and that and surrounding area covered in a film of LHM and crap. Do the regulators leak? Or will it be the spehere? Where the sphere joined the reg it looked to be quite dry.
LHM change scheduled for weekend, any info on above appreciated.
Paul
New Xantia owner with a couple of niggles
AndersDK
Paul -
Wipe the whole area around the spher & regulator - then have a look again after a couple of days - or this weekend.
The leak may emanate from several joints :
The regulator rubber overflow/return hose (cracked on stud).
The rigid pipe nuts seals.
The sphere mount O-ring.
Only the regulator return hose may be a "wallet" problem - the other bits are cheap.
infinicar
AndersDK
Donno Paul -
But try browse this thread - which gave me fears [B)] :
http://www.andyspares.com/discussionfor ... IC_ID=3835
infinicar
AndersDK
Paul -
That I'd take as normal -
When the car is set to highest height - the height correctors immediately opens for pressure to the suspension cylinders - taking all the pressure present. Result is a sudden drop in system pressure - takes a while for the pump to "top-up".
It MAY be indicative for a flat antisink sphere though - if antisink is fitted on your Xantia.
But this would commonly also show as a sudden drop in height when engine is started.
infinicar
infinicar
martyhopkirk
jeremy
martyhopkirk
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jeremy</i>
Marty
Sounds like the rapid end of acceptable - probably needs the non-return ball valve re-seating. lives under the accumulator sphere and just neds a smart tap with a brass drift. I can even do it on a BX without removing the regulator!
jeremy
Cheers - will get dressed and have a look![:)]
Marty
jeremy
