406 Speedo Fault
Post Reply
jonesgh
My Cars:
406 Speedo Fault
Post by jonesgh »
I have a problem with the Sagem speedo in my 406 coupe in that it only works intermittently. I have also noticed that the car seems to drive differently when it isn't working in that it lurches. Does anyone have any idea what's going on?.
My Cars:
x 729
Post by wheeler »
more than likely an intermitantly faulty road speed sensor at the back of the gearbox,this is what gives the speedo its reading.the engine ECU also uses infomation from this sensor which would explain the poor running when the speedo cuts out.
jonesgh
My Cars:
Post by jonesgh »
Thanks for that. Would a faulty speed sensor be recorded in the engine diagnostics?
My Cars:
x 729
Post by wheeler »
there may be a fault in the ECU memory because its loosing road speed info,you wont always get a fault code though,even if it comes up with a speed sensor fault it doesent neccisarily mean its the sensor thats at fault,it may be the wiring,the fault code just means there is a loss of information from it.my guess is a faulty sensor though
jonesgh
My Cars:
Post by jonesgh »
Thanks again, you seem very knowledgable about these things. Where would you recommend that I take the car to get this fault looked at? Is a Peugeot garage the best bet or are there specialists in this kind of thing?
Post Reply
