alternater belt keeps dying
tecw1979
Unread post by tecw1979 »
in the last 2000 miles my mi16 engine has done, the belt broke, then i found worn alternater bearings so replaced it, now the belt has broken agn in the zxs first proper thrashing. any1 else get this problem? im running the short belt as not air con fitted(yet)
alan s
RIP 2010
x 6
Unread post by alan s »
I haven't done a belt as yet, but my BX has air/con fitted & hence has a jockey wheel. When I bought a new belt, I thought ir was the wrong size and assumed it was for a series one without air/con, however as I also have access to one of those I checked it & found that whilst it was smaller than the original, it was also larger than the series one (no air/con) size.
I eventually discovered that the jockey wheel is apparently no longer made, hence the original sized belt is NLA and instead is replaced by one that goes from crank, to alternator & over the air/con pulley.
No matter how tight I adjust that belt, it still keeps screaming at me particularly on start up when cold, & the fact I have to keep adjusting it tells me that it's only a matter of time before it goes "boiiiinnnng."
If you find a cure or anyone elses experience would be most appreciated.
Alan S
AndersDK
Unread post by AndersDK »
Owners on the Swedish Citroen Q & A have reported that the only remedy to get rid of a screaming PSA engine belt - was to replace the screaming beltwheel.
If the belt snaps w/o a proper screaming warning - then the problem is a stalling driven device - or a wrong grade belt. I.e. the belt does not have adequate pulling strenght. Or it may run over-tightened.
Alternator V-belts should easy give ½ an inch on the long runs - when pressed with a thumb. The pulling relies on the V-shape & moderate belt tightening.
Donno about the MI16 engine - does this belt drive other peripherals than the alternator (non A/C) ?
alan s
RIP 2010
x 6
In my case it's not a "V" belt but a multi-v or I think it's sometimes called a serpentine belt. I presume the Mi16 would be the same.
Alan S
AndersDK
You're right AlanS -
Also used on the standard 16/19 engines.
Then look for any dents on the multirib wheels - if belt suddenly snaps w/o screaming.
Try look if a screaming multirib wheel have burnt rubber/dirt compacted in the grooves.
tecw1979
it has 5 sets of v's on this belt and is only for alternator... no aircon pump attached... 1/2inch of slack? maybe thats my prob i may have over tightened, which could also explain the last bearings going. well ill buy two belt incase it happens agn!!
alan s
RIP 2010
x 6
I don't think Anders means 1/2" on a serpentine but rather on a "V" belt. On mine, the "V" belt operates the hydraulic pump but the alternator belt is definitely the multi groove type which must be tighter.
Alan S
benj
Unread post by benj »
a bit off subject, but about two years ago i had a Porsche 944, now the alternator belt on this was quite hefty with the alternator needing to power quite a few on board creature comforts.
while driving home on the a41 north of whitchurch on a cold winters evening at rush hour the battery light came on, i promised myself to lok at it in the morning confident the battery would get me the 20 miles home.
well what had happened was the tensoining strut for the belt had snapped, well right about 5 minutes later came the scariest moment of my life, a loud bang then the car lifting up on the near side, scrapping and smashing all underneath the car, sparks flying, all at 50mph on a v.busy single lane road.
not having a clue what had happened as we screched to a halt, i thought id lost a wheel or something,
when i got out the car and examined the debrey id left it quickly became apprent that bits and pieces made up an alternator, and oh, looky over here an intact belt, not so much as a nick on it
what had happened is that when the tensioner snapped, the belt had wraaped around the alternator and crank sproket, instead of snapping, the belt ripped the alternator off the engine, the alternator attachement was still in one piece but the casting that holds it to the block, was completely wrecked, a massive casting held to the block by four long studf bolts i wish i took a picture of the damage,
normally people complain about squeeking and snapping belts, well heres one that went beyond all expectations of life expectency, shortned my life of about 5 years, and almost wrote of my porsche, respect.
x 1441
When the alternator seized on my BX TD the (multi groove) belt was so strong it just stalled the engine, and it couldn't be restarted until the belt was dropped off.
SWMBO was driving at the time, in traffic - I guess if it had gone at M-way speed it would have just shredded the belt after a few moments of low power. A few choice words were exchanged later that day (probably not helped by me saying "Oh, I wondered when that was finally going to give out")[:D][:D]
Richard
bxbodger
Unread post by bxbodger »
Just a thought, but a long time ago I had a 1500 Allegro that absolutely ate belts, and it turned out that when I changed the water-pump I refitted the pulley back-to-front; the pulley had an offset; it was only 2 or 3 mm, barely noticable, I certainly didnt notice it when i put it back on, but it was enough for the belt to run off line, and so shred at the edges and therefore break pretty quickly.
So, as you changed the alternator, check that the pulley was refitted in the correct place and the right way round, and its in line with the other pulley.
tecw1979
just found out i have less teeth on the alternator pulley... meaning a gti alternator??? oops... bett find a good fitting belt...
