brakes still squeaky
SHILTON
Unread post by SHILTON »
tried all the remedies that have been suggested but to no avail brakes are still squealing. Would wear in the caliper make them squeal?
after they are warmed up they make a squeeking noise when cornering to the left even when no pressure is applied although the calipers apparently are not seized or sticking.
closer examination of that disc shows that the bottom half of the disc is bluey in colour, overheating?
jeremy
x 3
Unread post by jeremy »
If your brakes only squeel when you turn to the left I wonder if your RH hub bearing is sound?
What car is this? - is this the Peugeot 405 auto? Do you know what brakes are fitted?
Jeremy
