Is this noise normal?
Fox
Unread post by Fox »
Hiya.
My Xantia always used to click constantly, and click with increasing frequency when I negotiated a hill at low speed (Probably at high speed as well, but I couldnt hear it then). I had the accumulator sphere changed, and how this has stopped! Hurrah [:)]
However it's been replaced by another noise, which happens more infrequently. It's quite hard to explain. It lasts for perhaps 1-2 seconds and no more, and I guess the easiest way to describe it is by saying it sounds like running your fingernail over a corrugated surface or something...
Is this a normal noise, or is something wrong?
Ta.
nick
Unread post by nick »
My Xantia has always made this noise, both before and after replacing the accumulator sphere. Its particularly noticeable when revving the engine at low road speed, like when climbing a hill, as you mention. I've known other Xantias do it too and always assumed its completely normal !
Nick
Dave Burns
x 3
Unread post by Dave Burns »
My previous L94 1.9D did it and so does my present R97 td.
Dave
akojic
Unread post by akojic »
Is there any chance that hyd. pump started to get noisy much more then before? At least pump on my Xantia is unusully noisy. Dispite that fact, works pretty fine.
