I am currently walnut blasting the intake valves of my 2011 DS3 1.6 THP, which is going fairly well I would say, but I am having a hard time reaching the last let’s say 5-10% of the carbon buildup, and I was wondering if some of you that are a bit more experienced could tell me if I need to keep going to get the valves to 100% or if what I have done is good enough. Please see attached images of all the intake valves
DS3 1.6 THP walnut blast question
Luisbassen
Hello everyone, hope you are having a wonderful weekend.
Also don’t be too hard on me, it’s my first time DIY’ing on the car
- x 8177
Re: DS3 1.6 THP walnut blast question
I find it difficult to see the results clearly in your pictures but you should be able to get the valves back to full shiny finish. Sometimes it can help to soak them with a carbon solvent and then blast again. Personally I have never used walnut shell as I have found the glass beads work well on heavy metal components
Luisbassen
Hi Mick - Thank you for the answer! I have actually used solvent (carburettor cleaner), but after getting them to the point of the pics above, the solvent just slowly drips through the valves, so the effect is quite limited I think. Some of the pics are a bit misleading, the colour/finish on the metal part of all of the valves are quite similar. The problem (and what I am wondering if is OK/acceptable) are the small amount of carbon around the edges of some of them
- x 8177
Sorry to say that it is the edges which are the most important as they have to bed perfectly onto the valve seats. A little carbon around the stem is less important but the edges need to.be spot on
Luisbassen
That’s exactly what I was hoping to not hear
Guess it’s back to blasting a bit more! How long would you recommend to leave the carb cleaner for it to have the most effect?
- x 8177
10 - 15 mins should soften it up
Luisbassen
Excellent, thanks a lot for the help, I really appreciate it
PaulC5
- x 725
If the engine is down on compression I would think the valves need grinding in as there will be wear on the surfaces.
Luisbassen
Thank you for the input, Paul! My plan is this:PaulC5 wrote: Yesterday, 21:35 If the engine is down on compression I would think the valves need grinding in as there will be wear on the surfaces.
- Remove as much of the buildup as i can
- Remove fault codes using obd, and fingers crossed that this solves my problem
- If not, then I’ll buy a compression test kit and see what the results of that says
PaulC5
- x 725
What fault codes do you have including their definitions ?
