There's an example in this post of a label showing that, in this case, 2.80 was fitted.
viewtopic.php?p=876079#p876079
Conversely this post shows a label that doesn't have the version printed.
viewtopic.php?p=876015#p876015
It is known that you cannot revert to an earlier version of firmware once a later version has been fitted. Whether that will be the same for a failed installation is not known.
RT6 2.75.c.5 Firmware / Software Download
- x 1955
Re: RT6 2.75.c.5 Firmware / Software Download
marion69120
Hi!
I have the black screen on my 308, i'm used to fix the rt6/rneg units but this time I'm stuck.
New SD Card 16gb, tried 2.86 through USB with no luck (no screen at all), same with 2.80
I noticed on my unit that the CD marking is linked to the 2.75 so I tried finding 2.75 files but seems like it doesn't exist.
I only have the 2.77
This time (with the 2.77) the unit finally "boots" and shows me the peugeot logo with a "CRC Checking" but it ends with a "CRC Error". Tried different usb etc but it is still doing the same. Atleast I know it is "working".
I want to try installing with a CD but the CD player of my unit is actually dead.
I am also thinking my 2.77 files are broken or missing some files. Could you send me also a link of the 2.77 version? @Paul-R
marion69120
just a quick update, after deleting weird files from my mac, .DS_Store etc it now pass the CRC check but i get stuck after "Disk check.." "Error during flasher loading". I tried multiple sd cards, I want to try a Sandisk but I don't have one atm. I tried Kodak, PNY and Hiksemi... Also tried the original Sandisk SD card but it is faulty and I still get the errormarion69120 wrote: 26 Sep 2026, 13:34 Hi!
- x 1955
Macs are notorious for dumping a load of hidden files and folders onto removable drives. It's best not to use one if possible but, if not, then all of them need to be deleted. There are apparently programs that can do this. If you're manually deleting them on your card using your Mac can you see the hidden files and folders?
Check your PM in five minutes for 2.77.
ThomasP
Hello,
I have a problem with my 2013 Jumpy Multivan. The multimedia screen stays black or lights up without displaying anything, and the CD player keeps searching continuously.
I removed the SD card and tried reading it on my PC, but it is unreadable. I suspect it may be faulty.
I tried flashing the system with version 2.86, but unfortunately, it didn't work. Would anyone happen to have version 2.77, which is the original version installed on my vehicle?
Thank you in advance for your replies, and I wish you all an excellent day!
Best regards,
Thomas
Best regards,
Thomas
- x 1955
@ThomasP
Check your PM. Usual disclaimers. Use at your risk, No warranties, etc.
Fredo2b
Good evening. I ended up solving my microsd partition problems which systematically crashed regardless of the firmware. The culprit was the microsd, in fact only the SANDISK brand works. Impossible to find in 8 GB, I managed with a 16GB installed as is, without formatting. It just goes to show that not all cards are alike. In any case, a big thank you to Paul for his kindness.
- x 1955
Thank you for letting us know of your successful outcome. Glad I was able to help.
Viljami
- New User
Hello.
My Peugeot 5008 (year 2014) RT6 radio has a black screen with probably a corrupted micro sd card because there is a CD startup noise. I don't know what the current software version is. Could someone help me and send me a link to versions 2.86 and earlier (USB) so I can test if some version will work for me.
