Hello
Anyone know ID and OD of o ring for cabin heat eexchanger?
Also material edpm?
Hole is 20.5mm and o ring might be tapered.
307cc cabin heater matrix o ring size
JollySpanner
Re: 307cc cabin heater matrix o ring size
On a 2003 307 2.0 petrol, an owner on peugeotforums sealed the pipe-to-matrix joint with 25mm OD x 2.65mm section Viton rings after the originals shrank and took a permanent set. Go EPDM or Viton rather than ordinary nitrile. Matrix variants differ, so measure your pipe-end groove and socket bore, or take the old ring to a seal shop.
