Smearing windows
Vic Evans
x 178
Smearing windows
Unread post by Vic Evans »
Mme took her new(ish) C3 out in the rain for probably the first time since she bought it & came back complaining that the drivers & passengers side windows did not clear after the usual quick up & down when she got in to return home.
I sort of had the same thing when I took it out a few days ago but ignored it!
This morning I checked the horizontal 'double' rubber seals which seemed reasonably tight when I tried to insert a very thin piece of plastic carton between them & windows.
I've eased out the inner seals by sliding my finger between that & the outer & await to see if Mme still complains.
I'm thinking maybe I could try wiping the seals with a bit of washing up liquid to clean 'em but failing this any ideas if there's anything else I can do?
Edit. just thought. It's not been washed since the selling garage washed it with a note to the effect that it wasn't a good job due to water restrictions. Maybe something left on glass?
PaulC5
x 724
Re: Smearing windows
Unread post by PaulC5 »
Possibly the seller polished the car so it looks good and there might still be polish on the windows. Washing them with water and washing up liquid should clean them. I use an old wiper blade if needing to clear windows before setting off.
Vic Evans
x 178
PaulC5 wrote: Yesterday, 12:41 Possibly the seller polished the car so it looks good and there might still be polish on the windows. Washing them with water and washing up liquid should clean them. I use an old wiper blade if needing to clear windows before setting off.
Just cleaned? windows with warm water & washing up liquid. Didn't make any difference.
Mme's off out with car in rain so I'll see if any better when she returns.
ekjdm14
x 281
Unread post by ekjdm14 »
Could be their particular brand of "wash n wax", I found if that kind of all-in-one stuff is used it leaves a nasty smeary coating on all the glass. Might take a while to wear off if it's got between window & rubber but should self-correct with time & no wax going on window.
'95 Xantia LX 1.9D-auto, Black, 123k
'96 ZX SX 1.9TD, White, 90k
'87 Nissan Sunny 1.3L, 63k
'12 Mini freebie project
x 5690
It may be worthwhile cleaning the glass with meths, then a washing up liquid solution.
Vic Evans
x 178
Cheers all for replies.
Maybe my description of 'smearing' was not explicit enough as it appears that maybe the seals are not 'tight' enough as they don't seem to wipe any water off the windows.
I've only had two quick 'plays' with the problem so it's not conclusive as it could be the windows are wiped going down with water replaced going up but difficult to be sure.
I need some non rainy time to experiment outdoors & give the glass a really good clean to eliminate that problem.
