Looks like I'll be scrapping the 24 year old C5 2.2 Mark1 diesel - very sad
C5Mark122
Unread post by C5Mark122 »
Hi all,
I think it time to let go. Just wondering if there is any advice out there . . .
Very sad - looks like I'll be scrapping the 24 year old C5 2.2HDi Mark1 diesel. Only - 73k miles !!!!
Still drives really well but needs ABS pump corrected to clear the messages and pass MOT.
ECU Testing looked at it but it came back as 'Beyond Repair'.
Good clean car inside and out. Pet free. Garaged. Large estate car with roof rails. Wing mirrors and windows intact. etc. honestly :-(
Any advice. Spares for a car this age are similarly aging. Repair costs creeping up so feels like .. the End of the Road.. . . . .
Tom
x 8176
Re: Looks like I'll be scrapping the 24 year old C5 2.2 Mark1 diesel - very sad
Probably worth having a scan and seeing what fault codes are stored before making your final decision. :)
C5Mark122
thanks v m for the reply,
Autel gave C1350. The garage said the electrics were fine, and sent the unit to ECU Testing. Unfortunately it came back from them with the description "Beyond Repair" ... the garage themselves were disappointed. They said it was rare that they were told units could not be repaired.
x 8176
It may be worth trying something like this as it is not too expensive!! :)
https://www.ebay.co.uk/itm/137573514305 ... Model%3AC5
PaulC5
x 724
Unread post by PaulC5 »
There is a topic here where C1350 was fixed by replacing the abs pump so if you can get a replacement cheap enough it is worth a try. Also on a 2002 C5 Estate HDi. 2.2. Auto viewtopic.php?t=58737
C5Mark122
thanks folks, I've added a message to the owner on the old 2002 C5 Estate HDi. 2.2. Auto topic from 2017 to see if he tells me the car had a good future after months of work. I'd go for the ebay part from Lithuania if time was on my side ( certainly cheap !) , but I'm getting poor vibes from garages and the few links I find for the 2nd hand route and reprogramming required ...
PaulC5
x 724
If you get a new rather than used abs pump it would still need programming, we had a C4 that needed one after a crash and that had to be programmed by the repairers. It also needs the diagnostic to bleed the abs pump as without it all the air can not be removed. If you do not want to pay for the diagnostic then scrapping the car will likely be your only option.
If the garages you are trying are not Citroen specialists then you could try Pleiades, contact details here viewtopic.php?t=27692
C5Mark122
thanks Paul,
I don't think I can get the new part anyway, and another old secondhand part feels a big gamble.
I think I will go for a 2nd opinion on getting the ABS pump unit repaired. I have read that sometimes one company can't fix it, but a 2nd one tries and can. So reading that, I still have a little hope! I hope to get the view from the 'chief mechanic' at the garage on Monday.
x 1506
It's unlikely it is a proprietary item - who is it made by? With the numbers off it you might be able to source one from a different car? What actually is wrong with it?
ekjdm14
x 281
Unread post by ekjdm14 »
RichardW wrote: Yesterday, 15:56 It's unlikely it is a proprietary item - who is it made by? With the numbers off it you might be able to source one from a different car? What actually is wrong with it?
Seconded, anything made by humans can be repaired by humans. Sometimes all it takes is someone with a little knowledge (and/or the old-faithful percywhatsit) and if you like the car a lot/know it to be good otherwise then I'd certainly rather spend a few hundred quid on repairing it one way or another rather than chance it with another used car or, God forbid, something newer! 73k is absolutely nothing for an old HDi, probably only 10% through it's reasonable lifespan if the rest of the car can be kept up with.
'95 Xantia LX 1.9D-auto, Black, 123k
'96 ZX SX 1.9TD, White, 90k
'87 Nissan Sunny 1.3L, 63k
'12 Mini freebie project
C5Mark122
Hi Richard,
ATE MK60 ABS Pump - internet tells me that the version required for a 2002 C5 Mark 1 was last made in 2004 (or possibly 2006 for spares)). The ATE MK60 ABS Pump was updated later C5 versions.
[ the detail bit from the web .. The Mark I (2000–2004) uses Citroën's older VAN-bus wiring system, while the updated Phase II (2004–2008) uses Full CAN-bus electronics. Their ECU pinouts and digital protocols are completely incompatible, meaning neither unit will communicate with the other car's systems, even if you attempt diagnostic reprogramming with Lexia or DiagBox. ]
Secondhand I would need another low mileage similar Mark 1 - I suspect at 73K my is 'fairly' unique.
Per my note above, it went to one of the 'big repairers' and just came back as "Beyond Repair". I'm thinking of using one of the smaller companies, and hope to at least get a better explanation. Peace of mind at least that I've tried
ekjdm14
x 281
By the way, just done a bit of digging and the OP of the other 2.2HDi/ABS thread has not been online since 2022 unfortunately. Looking through their posts though, the C5 was mentioned in other replies regarding fuel economy and Eolys fluid up into April 2019 so I'd hazard a guess it carried on for at least another couple of years after the ABS was repaired.
To be honest, I think it's not so much mileage that would cause the C1350. When I look at the Citroen specific definition it seems more of an electrical circuit code than a mechanical/wear fault so likely just bad luck that yours has failed & quite possible a high mileage replacement would work for many years.
C5Mark122
thanks v m for checking things out on this,
If it's a crack in the soldering, I'm hoping that can be fixed by a decent attempt to repair. I'd like a replacement to last a long time, and I think this is best guaranteed by finding and fixing the fault in the existing one if they can.
ekjdm14
x 281
Agreed, if your unit is actually repairable then that's preferable. Hopefully it is and is just a case of finding someone who wants to make the effort, you see this a fair bit with older modern cars. Too old for modern repair companies, too new for classic specialists, hopefully between the members here we can find the person for the job. Might be worth a look through the recommended garages/services forum to see if anyone has posted someone in there.
PaulC5
x 724
These people suggest they can repair abs pumps, possibly you have already asked them, £264 though and then you need the diagnostic to bleed the brakes once installed so around £400 total
https://www.autotronics.co.uk/product-c ... nd=citroen
