2015 Peugeot 208 Mk1 1.6 GTi 200 hp Petrol heater issues
admiral51
(Donor 2026)
x 392
Unread post by admiral51 »
Hi all,
I have ditched the Citroen badge and come over to the dark side, defo having a midlife crisis now i have free prescriptions and a senior citizen railcard in good old blighty :rofl2:
I have had said car for 3 weeks and somehow no points yet ( God Bless Royal Mail ) but i digress.
Bit of history of the vehicle.
89k miles, Cam Chain/water Pump and full service done in May 2026 @ 85k.
My issue is that the in cabin temperature is not as warm as i feel it should be. I am going to put in the mix that i had a similar problem on my 2010 C4 which ultimately was fixed by changing the heater matrix but the C4 did not have a temperature guage, the 208 does and it seems not to be that accurate. It will rise to 70 after about 5 mins driving and stay there for my 25 min drive yet other times within 5 mins it will reach around 95 and stay there until switched off. On restart after filling up with fuel it will drop to around 75 and stay there until being switched off. The External temperature reading is good as i can check with other people at work, we are all around 1.5 degrees between each other if that makes sense.
The in cabin temperature really doesnt change that much regardless of the engine temperature guage so i am leaning towards a semi blocked heater matrix and a faulty temperature sensor.
The higher the fan speed the cooler the air gets, not saying it gets cold but you can feel the difference.
Anyone have any different thoughts as i am thinking of replacing the sensor, a heater matrix change and a coolant flush is the way to go.
No i do not have bottemless pockets so any ideas on time/price to do the job would be appreciated [-o<
Colin
x 8176
Re: 2015 Peugeot 208 Mk1 1.6 GTi 200 hp Petrol heater issues
Can you run a scan and see what codes you have Colin? :)
PaulC5
x 724
Unread post by PaulC5 »
If you do a scan look at the coolant temperature, it could be the thermostat is faulty and opens too early so the coolant does not warm up enough.
admiral51
(Donor 2026)
x 392
Paul I have had a Google and it seems the thermostat should be 105 opening which to me seems way to high.
Will probably need to check it over the weekend when I have some free time
JollySpanner
Unread post by JollySpanner »
Check the live coolant temp with your Lexia before buying anything. The THP thermostat is map-controlled so some wander is normal, but a steady 70 is not. Then feel both heater hoses at the bulkhead. Both hot but lukewarm air means a blend flap, not the matrix.
admiral51
(Donor 2026)
x 392
mickthemaverick wrote: 25 Nov 2026, 21:18 Can you run a scan and see what codes you have Colin? :)
Hi mick.
i will do over the weekend
Colin
admiral51
(Donor 2026)
x 392
Just a quick update from todays exploits.
Cannot find the charger for my laptop i use for the Lexia, so Amazon will deliver a replacement tomorrow so i can then do a scan.
However i have found a scenario that works and gives the same results each time, something i hadnt thought about until yesterday evening.
Since i bought the car i have 99% of the time had the A/C and blower on as soon as i start the car whether it be 04:00-06:00 on my commute to work or 15:30-17:30 on my return depending on start/finish times.
This results with the temperature guage reaching 70c give or take and staying there for the entire journey.
It was yesterday i left everything off and within 3-5 mins the temperature guage rose to just over 90c maybe 95c. I did the same this morning @ 06:15 and within a mile the temp was showing just above 90 and stayed there for my 25 minute journey to work. I did the same on my return journey and again temp moved to just above 90c within 5 minutes.
Now the internal temperature was lukewarm once the blower was turned on, bearable but not hot. However i got caught in some traffic tonight and with the blower set on half speed and temp set to high the heat coming out was much hotter as i could reach down and feel it. The vent settings were switched off, just the auto setting but with manual fan settings if that makes sense to people.
Now as soon as traffic cleared, with temp guage showing 90c ish and no internal changes the heat from the vents became luke warm.
Maybe just coincedence or wishful thinking.
Will get a live scan done over the weekend.
Colin
pucetic
New User
Unread post by pucetic »
Je suis également passé en remarquer un problème avec la température ambiante intérieure sur ma 208, même si la température indiquée ne semble pas très précise. J'ai essayé de nettoyer les réservoirs de réfrigérant, mais cela n'a pas résolu le problème. Il se pourrait que le circuit de chauffage soit en cause.
🇫🇷 French Automobile Enthusiast | Keeping classic & modern French icons on the road!
x 8176
@pucetic
Please have a look at the rules of the forum which you can find at: viewtopic.php?p=864089#p864089 with attention to Rule A1 and the E section. I believe your signature may be in breach so please amend it accordingly. :)
PaulC5
x 724
admiral51, it looks to me as if the thermostat is at fault. With the a/c on the engine fan will be running so cooling the radiator. Switching it off the coolant will warm up a bit quicker if the thermostat has opened too early due to being faulty.
pucetic
New User
J'ai remarqué le code P2181 sur ma 208 avec 89 000 kilomètres au compteur, et la chaleur intérieure n'est pas ce qu'elle devrait être. J'ai déjà essayé de nettoyer les réservoirs de liquide de refroidissement, mais cela n'a pas résolu le problème. Peut-être qu'une vérification du thermostat ou un reset du système serait utile.
x 1955
@pucetic
Please translate your posts into English. This is an English language forum. Use an online translator if necessary.
admiral51
(Donor 2026)
x 392
@pucetic
thanks i have not done a check for faults yet but will report back here.
@PaulC5
Today leaving work i kept the A/C off but the fans on half speed and for 5 miles the guage didnt budge even close to 70c so i turned the fans off for a couple of miles and still no movement. I stopped the car, switched it off,locked it,unlocked it, put ignition on with fans off and the guage jumped straight to just around 90c before starting the car. It stayed there for the rest of the journey with fans on with the same results as yesterday when caught in traffic. In car heat feels cooler when the car is in free flowing not stop start traffic.
I really do not understand what is actually going on, i need to run a scan but something is wrong 😢
Oh anyone have any idea where the diagnostic socket is located #-o #-o
Colin
PaulC5
x 724
It still looks to me as if the thermostat is opening too soon so coolant is going through the radiator all the time. When the car is moving quickly the radiator will cool more than if in slow traffic. A simple check is to start the engine and feel the top radiator hose, it should not start to get warm until the engine is up to temperature at the thermostat setting which you say is 105°C. If the hose gets warm before the engine is about 105°C then the thermostat has opened too soon.
A quick search suggests the diagnostic socket in inside the passenger side glove box but you might need to pull off a cover in there to see it.
When you stopped the engine and then started it again, the residual heat in the engine will have warmed up the coolant around the temperature sensor as it will not have been circulating, hence a reason why it may have gone up to 90°C.
