Hello,
I am looking for the part number for number 16 - the in block dowel pin - in the illistration.
In the PSA (Peugeot/Citroën) timing diagram shown on the eBay listing,
part 16 is a dowel pin / locating pin (or spacer/busher) used to align and position the timing belt tensioner/idler assembly
against the engine block or cylinder head.
2009 - Peugeot 308 CC 2.0 Diesel. Will not start.
Issue is = Cranks ok, won't start. Current state of troubleshooting is that we found this dowel fell out 'crushed' when we took the plastic cam cover off.
We found the tensioner was not tensioning the belt and currently believe the crank sensor and cam sensors do not agree with each other due to the slack belt.
But for now I just can't find this dowel part number - and so where to order it from. I am in Cambridgeshire, UK.
Thanks for your help.
Need part number for dowel pin / locating pin 308 2.0 diesel.
308CC-20Diesel
- x 8173
Re: Need part number for dowel pin / locating pin 308 2.0 diesel.
308CC-20Diesel
Thanks mickthemaverick - very quick response much appreciated.
I got the same "partial" info from 7zap.com .. but it took me some time - and is only partial without paying for subscription.
Will try and purchase the part now - thanks again.
