ds5 2018yeer diesel fuel pump diagram
Rayds5-
New User
Unread post by Rayds5- »
hi, i have problem with the car starting, having the fuel pump remove and found it is a uvw 3phase pump, so i found the voltage among the uv, vw is fine but the uw doesnt have voltage at all. anyone has the wiring diagram and i would like to trace the wire to find out the problem, thanks for your time reading and your generous sharing. cheers.
PaulC5
x 722
Re: ds5 2018yeer diesel fuel pump diagram
Unread post by PaulC5 »
Have you had a diagnostic done to see what is wrong with the car, if so what did it find ?
