The tales of a broken Zoe!
DHallworth
x 170
Unread post by DHallworth »
Welcome to the tales of a broken Zoe...
Whilst browsing eBay on Friday I searched for "Spares or Repair" out of curiosity and up popped a 2013 Renault Zoe. It was advertised as "Spares or Repair" as the seller said he had a fault with a relay that was inside the charge filter. The charge filter was replaced with, I believe, a used unit. The fault code for the charge filter has gone but it's now got 2 active codes and 1 that's in the memory.
The codes are:
DTC041168 - CAN communication - Active
DTC1525F3 - Consistent Multiplex Signals for CC/SL - Active
DTC0432F1 - Safety Interlocks - Memory
I had a chat with Mrs H and we decided it could be quite handy for us given that both our cars are diesels and most of our trips these days are short ones so we stuck a bid on it and won it for £501.98. As I've got no idea what the battery state of health is, my maximum was going to be £500 but I decided to make it an odd number. The winning bid was my maximum. The car is in Hexham and I looked at going to get it with the trailer but a quote from Shiply to have it delivered came in at £260 for someone who was coming North with an empty trailer so it wasn't worth my time/diesel/etc. to go and fetch it.
The car isn't due to arrive with me until Wednesday at some point so I can't start doing much until then. I've never so much as looked at or sat in a Zoe and I won't even have seen this one before it's been paid for and transported here so it's an interesting experiment. :lol:
Seeing as I like a challenge and having never worked on an EV I thought this could be quite interesting.
Anyway, here's a few eBay pictures until it arrives.
David.
'98 Xantia Activa V6 :-D
'13 Renault Zoe - Broken
'15 C4 BlueHDi Feel - For Sale
PaulC5
x 721
Re: The tales of a broken Zoe!
Unread post by PaulC5 »
Whilst waiting for it I would contact your local Nissan dealer and get an idea of repair costs unless the previous owner has already told you.
x 2008
Unread post by Stickyfinger »
Add these to the tool kit :) (I do not think you could carry an Afro hair style)
x 697
Unread post by Mandrake »
PaulC5 wrote: Yesterday, 13:04 Whilst waiting for it I would contact your local Nissan dealer and get an idea of repair costs unless the previous owner has already told you.
Nissan ?
I thought Nissan and Renault were trying to part company after Carlos Ghosn fled from Japan ? :lol:
x 697
DHallworth wrote: Yesterday, 12:03 I've never so much as looked at or sat in a Zoe and I won't even have seen this one before it's been paid for and transported here so it's an interesting experiment. :lol:
You're a tall fellow and the Zoe is a small car, should be interesting! :lol:
To be fair I've never sat in one either, so maybe the legroom is better than it looks.
DHallworth
x 170
I'm planning on doing it all myself, it won't be going near a garage :)
Stickyfinger wrote: Yesterday, 13:22 Add these to the tool kit :) (I do not think you could carry an Afro hair style)
Was thinking about looking for a pair of those. Kinda convinced they're a bit overkill but best not to take chances I guess.
Looking forward to your posts and the successful resurrection of the Zoe!
The go to diagnostic thing appears to be CanZe and a wi-fi or Bluetooth dongle plugged into the OBD, and as suggested before and elsewhere Gary C's you tube channel has plenty of helpful videos on your initial problem to solve. There will be plenty of life left in the battery even at 13 years old, and always the possibility for an upgrade from the 22kWh battery which I presume your Zoe has, to a 40kw Battery.
x 697
Does CanZe do everything the Autel diagnostic tool Gary C uses though ? I doubt it.
It's probably the equivalent of Leafspy - a very useful tool but not a replacement for an actual diagnostic tool.
x 697
DHallworth wrote: Yesterday, 13:31 Was thinking about looking for a pair of those. Kinda convinced they're a bit overkill but best not to take chances I guess.
I would never suggest anyone take less precautions, but I had the traction battery removed and stripped apart for a cell swap in my Peugeot Ion and I had no such gloves available to me.
But I was very careful and I know what I'm doing around electronics. Someone without the necessary experience and knowledge poking around inside a traction battery definitely could kill themselves. Unlike an AC shock, you can't let go of DC.
However if you are not opening the traction battery enclosure and safe the battery by removing the safety plug (I assume the Zoe has one) you can't get a shock on the outside of the enclosure.
The safety plug is usually a link in the middle of the series string inside the battery - it breaks it apart into two disconnected batteries.
On the Zoe specifically, take care not to disconnect or connect any orange high voltage cable while the 12v battery is connected - one of Gary's videos points out that the Zoe periodically does activate the high voltage system, for example when opening a door, which is a bit odd as most EV's don't do this when opening a door!
Inside the traction battery are three high voltage contactors which have to close to apply power to the exterior circuits - one is for the pre-charge resistor and only turns on for a moment, the other two stay on when live.
If the 12v battery is disconnected there is nothing to power those contactors. If you have the safety plug disconnected on the traction battery and 12v battery disconnected and the traction battery enclosure is closed, there's really nothing you can do to get a shock gloves or not.
CanZe very useful tool in its own right , and one worth having for the Zoe owner. Unlikely to match all the functionality offered by a tool as used by Gary C. as a professional Zoe mechanic as you say Simon.
Bit of background on the original CanZe project https://canze.fisch.lu/
With the end of the production of the Zoe, the project came to a natural end, although a derivative app for the Dacia Spring CanZe Plus is available on google Play along with the original CanZe for the Zoe by Bob Fisch et al.
https://play.google.com/store/search?q= ... s&hl=en-US
Not the World's leading expert on these things, and never personally used the CanZe app but over ten thousand have and added bonus....may even be free!
DHallworth
x 170
I watched a video of Gary's where he was troubleshooting an interlock fault with his Autel. To monitor the state of the interlock switches you need to have the high voltage battery isolated but you need to have the 12v connected so that the diagnostics tool can talk to it.
The seller did mention that the 12v battery is a couple of years old so maybe the first thing I should do is remove the battery and recondition it for 24hrs and try again.
DHallworth
x 170
Generic diagnostics dongle for CanZe has been ordered this morning. Due to arrive this weekend. Unfortunately Amazon must be swamped by Black Friday as nothing on Prime is next day at the moment.
Le Leccy Baguette has now been paid for in full, collection is due to take place this afternoon/evening and it will be delivered to the house whilst I am at work tomorrow.
I should be home just before 3pm so at least I'll get to see what it looks like in daylight hours!
Very much looking forward to following your progress towards a fix David.
