C4 Cactus BlueHDI 2014 left hand drive (VIN: VF7**************[VIN obfuscated, can be read by forum staff]):
A couple of months ago I noticed that when I put heating to max heat after starting the car, then after about a minute or so it starts to smell of burnt plastic (best way to describe it). It goes away after 10-15 minutes when the car is hot, so I have narrowed it down to some sort of electric heating element that kicks in when the car is cold.
Does anyone know anything about this? I have found a thread on here about an "auxiliary electric heater". I think it could be it, but according to Citroën part 3 in the diagram below is now an electric heating element, but rather a heat exchanger. Can anyone point me in the right direction? Where is the electric heating element placed?
C4 Cactus BlueHDI smell of burnt plastic when heating on max
martin_b
- x 8
martin_b
- x 8
Re: C4 Cactus BlueHDI smell of burnt plastic when heating on max
Update: I removed the fuse for the "Additional heater (Diesel)" and the smell went away. So it seems the fault is coming from that electrical heater. But the question still remains: is it part (3) in diagram and is it replaceable?
PaulC5
- x 718
A search suggests it is part no. 6436H5 and there are many available to buy new or used, as an example https://www.autoparts-24.com/item/A_0031_GM03249/
If you remove a side panel in probably the driver's footwell for left hand drive, you might be able to see it and undo/remove it. Other parts diagrams suggest the heater could be more horizontal than in your diagram.
The smell could be it is just dirty and needs a clean or a cable or connector could be burning out.
martin_b
- x 8
Thanks for the reply. The part no. you provide is indeed part (3) in the diagram I posted. Some sites say that it is not an electrical heater, and some say it is. Hence my question. I will see if I can access it by removing the side panel in the footwell.
