May I request the parts drawing for above showing location & if possible replacement procedure ?
Background: Occasional but not always multiple attempts on Start/Stop error depress clutch & press...
Verified via Diagbox both the 'pedal pressed / released' & the 'clutch pedal position' fields in the ECU/Misc info menu. The % field linearly increased with no spike or skips as I pressed the pedal and ~ 24% the 'pedal pressed' field came true, full pedal travel 100% & 0 = 0%. This would suggest no issue BUT in multiple starts just today (as in other days) their was no 'depress clutch' warning, again intermittent & it can go days with no issue.
508 - 2016 2.0hdi Clutch Master Cylinder Information request
Gerry_123
- (Donor 2026)
- x 8165
Re: 508 - 2016 2.0hdi Clutch Master Cylinder Information request
Unfortunately the forum has lost access to the Stellantis database so I cannot help. However there are members with their own access and hopefully one of them will see your request and help out. Good Luck
Gerry_123
- (Donor 2026)
Thanks for the update. Is it possible for a non vat, diy'r do get access & if so is it possible to search by hourly rate ?
Gerry_123
- (Donor 2026)
Can anyone advise if the cylinder is removed from pedal side or firewall side ? Thanks,
PaulC5
- x 714
This topic on the Peugeot forums should help. It appears the master cylinder is removed from the engine side of the bulkhead after turning an eighth. It includes the Peugeot procedures. https://www.peugeotforums.com/threads/c ... um=organic
Gerry_123
- (Donor 2026)
Thank You. & its partly visible with removing anything (on LHS of vertical AC pipe).
