Rear courtesy light
Siims76
- New User
Rear courtesy light
My rear courtesy light doesn't work I've tried replacing the bulb and light unit and followed the loom from back of the light and unwrapped the loom as far as it goes into the glass unit. Where is the most obvious place to check . I am getting 12 volts on multimeter but not sure what else to check 2008 308 cc gt 2.0hdi
- x 8163
Re: Rear courtesy light
If you have 12V at the light and a good bulb then the earth connection may be suspect. Try a wire from a body screw to the other side of the bulb and see if it lights.
