Keys unpaired & can't access bonnet
EEE1
Post by EEE1 »
Hi All,
I made the unfortunate mistake of buying a Citroen with a PureTech engine. Long story short, the engine failed and the car has been stored in our garage for a few months. We tried to move it today ready for an independent inspection, but it seems the keys (x 2) have unpaired with the car. Could they have unpaired because the battery is flat?
If it's a flat battery issue, we can't open the passenger door wide enough to access the bonnet release handle (garage wall in the way) so can't access the battery and as the car won't recognise the keys we can't get the automatic handbrake off to move the car so we can open the door either!
What the heck do we do now?
This car will be the death of me!
x 8163
Re: Keys unpaired & can't access bonnet
Post by mickthemaverick »
Can you not go in through the driver's door and lean across to pull the bonnet release? :)
x 1952
Post by Paul-R »
The bonnet release is probably on the A post and only accessible with the door open. That's the way it is on our 308 and C5.
x 8163
That's probably true Paul but he said he couldn't open the passenger door wide enough, which means it may be wide enough to access the handle with a hook or similar when in from the other side. Just an idea! :)
PaulC5
x 710
Post by PaulC5 »
If you can get in the car and put it in neutral you could put dollies under the rear wheels and drag it out. Trolley jacks might also be possible at the rear. If trying these put chocks at the front of the front wheels so the car can not move forwards as it is lifted up. Another possibility is to put cardboard under the rear wheels and drag the car out.
EEE1
Post by EEE1 »
We can access the release handle, but can't pull it high enough to pop the bonnet as the storage compartment at the bottom of the door gets in the way.
I don't think we have enough space to use jacks. Dollies could be a possibility but we'd have to buy them. How do you stop it rolling away once on the Dollies? How do you even get it on the Dollie's, not sure I'm strong enough for that :rofl2: (I'm a she btw). Cardboard might be an idea, how would that work? Cardboard under all the wheels and just push/pull?
EEE1
Post by EEE1 »
I've just realised you said Dollie's under the rear wheels. So does the automatic handbrake only apply to the rear wheels? Does that mean someone can sit in the front and apply the brakes manually if necessary when moving it forwards then back again?
