C5X windows and locking car
Sloppysod
x 406
Re: C5X windows and locking car
Unread post by Sloppysod »
GPH_1969 wrote: 14 Nov 2026, 19:58 land should be lane! How do I determine the build date?
Oops my bad, I shouldn't have just copied and paste from your post! :lol:
My got my build date is from the "Certificate of Conformity" I got with the car.
As you gave just bought the car check to see if it is in the scope of these recals
https://www.vehiclerecallcheck.co.uk/ci ... -2025-283/
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
GPH_1969
Unread post by GPH_1969 »
Sloppysod wrote: 15 Nov 2026, 08:49
Just had a look and there are a few listed, most recent April 2026. I assume these are done as it was services in October. How would I tell? Also, the Citroen App says no current recalls due.
Sloppysod
x 406
GPH_1969 wrote: 15 Nov 2026, 09:27 Just had a look and there are a few listed, most recent April 2026. I assume these are done as it was services in October. How would I tell? Also, the Citroen App says no current recalls due.
I think the only way for sure is contact Citroën UK, I seem to remember, but I may be wrong as I have been once before that most of the recalls were for the 1.2 engines. But better to ask rather than assume.
As for the app......it's (Cr)app. You will find out that occasionally a journey will be lost, send journey to car fails (this also needs subscription), service records are not kept upto date and have to be manually added, then lost, and apparently we'll you transfer ownership the records are deleted! Also see below, spot the error..
Spoiler: show
My car is not 4 years old yet and is just shy of 23,000 miles (37014.91km)
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Richard_C
(Donor 2026)
x 238
Unread post by Richard_C »
GPH_1969 wrote: 14 Nov 2026, 07:23 I'm almost tempted to pay the £90 annually for Citroen Connect Plus so I can use the built in TomTom satnav and get full hud back...
Save your money, it's rubbish at routing and rubbish at traffic updates - especially when jams have cleared but it still routes around them. Google maps is normally much better apart from sometimes missing late night closures. . Its best trick was to show petrol prices but google does that now.
If you lower the HUD (assuning yours is that type) you might get full google nav on the speedometer screen.
My C4, presumably very similar avionics, does the window thing in theory but not in practice. I keep my handbook in the fiction section of my e-books.
Richard_C
GPH_1969
Sloppysod wrote: 15 Nov 2026, 10:50
As for the app......it's (Cr)app. You will find out that occasionally a journey will be lost, send journey to car fails (this also needs subscription), service records are not kept upto date and have to be manually added, then lost, and apparently we'll you transfer ownership the records are deleted! Also see below, spot the error..Image
Spoiler: show
Yes, it does seem more trouble than it's worth. One for the app bin I think.
GPH_1969
Richard_C wrote: 15 Nov 2026, 11:42
Yep, I'll be sticking with android auto too. I'll give the HUD idea a try, thanks.
GPH_1969
I went out on my first proper drive today including a bit of the M3.
Positives:
Lovely drive. It's just the 1.2 (was looking for a 1.6 but they are rarer than hen's teeth), but it performed amply and not harsh at all.
It's my first car with Speed Limiter, and I really appreciated it.
Cruise Control worked really well too. Haven't tried it in crawling traffic yet.
Rear camera washer finally started spewing water. I assume it just needed a few goes after sitting on the forecourt.
Negatives:
Low autumn sun was blinding on the M3 with a wet road bringing up dirty spray but no rain - almost Impossible to see at times. Anyway, at that point I once drifted slightly to the edge of my lane and the Lane Departure Warning went mental. It must have been 10 seconds of constant beeping after I corrected. Just a couple of beeps would have been sufficient. Ridiculous overreach.
Journey out was fine, but on the return on 3 separate occasions the car beeped while warning me to keep my hands on the steering wheel. The third time this went on constantly for maybe 2 minutes until I stopped at a traffic light. Each time both hands were firmly on the steering wheel and I even tried give it a little wiggle to say 'Look, my hands are bloody on!!'. Assume this is a potential fault. Anybody else experienced this?
Sloppysod
x 406
GPH_1969 wrote: 15 Nov 2026, 16:32 .....The third time this went on constantly for maybe 2 minutes until I stopped at a traffic light. Each time both hands were firmly on the steering wheel and I even tried give it a little wiggle to say 'Look, my hands are bloody on!!'. Assume this is a potential fault. Anybody else experienced this?
I think your hands need to be nearer 10-2 position, and not at the bottom.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
GPH_1969
Sloppysod wrote: 15 Nov 2026, 21:59
Hmmm, I reckon they were at the time. The manual says hand-on detection may fail if thick gloves are worn or the steering wheel is covered; not the case here. I'll give be it another try, maybe it's to do with grip strength...
x 5679
GPH_1969 wrote: 16 Nov 2026, 07:17 Hmmm, I reckon they were at the time. The manual says hand-on detection may fail if thick gloves are worn or the steering wheel is covered; not the case here. I'll give be it another try, maybe it's to do with grip strength...
Perhaps it detects movements and fluctuating pressure.
GPH_1969
Another question:
The manual said a service reminder will pop up before next is due. Is there a way to check when it thinks this will be? I've gone through the manual, but it's all a bit vague.
Sloppysod
x 406
Three fingers on main screen, this takes you into the "Settings" screen. Then find vehicle on right hand side............... - and that's how far I can get without going out in the cold. If I remember correctly the distance to next service is in there. Don't worry, my car is due in 4 months and a message popped up the other day so it wont let you forget.
Spoiler: show
If you fail to get it serviced in time, it turns into a pumpkin!
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
GPH_1969
Sloppysod wrote: 16 Nov 2026, 17:43 Three fingers on main screen, this takes you into the "Settings" screen. Then find vehicle on right hand side............... - and that's how far I can get without going out in the cold. If I remember correctly the distance to next service is in there. Don't worry, my car is due in 4 months and a message popped up the other day so it wont let you forget.
Spoiler: show
3 fingers! I would never have guessed that in a million years. Thanks, will give that a try tomorrow.
Sloppysod
x 406
If you hold them on for about 5+ seconds you get to the professional screen - "Beware them Dragons" as the saying goes. Basically look but don't touch.
Used if having difficulty with updates
....hold 3 fingers on the screen until the keyboard appears, enter code 1232020 and then you are in the advanced menu.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
GPH_1969
Spoiler: show
Hi, I tried this out but couldn't see anything service related, I'm probably just being a bit blind.
From the manual:
Reminder of the servicing information
Servicing information is accessible using
the “Check” button in the
Settings>Vehicle touch screen application.
I see no "Check" button:
