C5X windows and locking car
GPH_1969
Unread post by GPH_1969 »
Hi,
I've just got a used C5X in Shine Plus trim - lovely car.
I have a couple of questions:
1) The handbook states that all the windows can be opened / closed using the key fob, but this isn't working. Is this not included in UK models?
2) Is there any way to disable the chirrup sound it makes whenever it locks?
Cheers.
Tigerseye
Re: C5X windows and locking car
Unread post by Tigerseye »
Evening GPH-1969. To be honest I've never tried to use the window closure/opening from the fob . I'll have to check it and get back to you. I think I've seen the option to stop the locking sound under the vehicle setting menu (under vehicle option - Access - Locking), but I'll check when I look at the windows thing.
I have noticed that there are some things different in reality from the brochure spec though. E.g. In mine (Hypnos) there is no ambient light under the dash, although the brochure seems to suggest there is. Apparently Citroen just didn't include it in UK specs (thanks Citroen!). I do really like the car though so I can overlook some of the omissions.
Anyway, I'll check on the above and post again. All the best.
GPH_1969
Hi Tigerseye,
Thanks for the reply. I found the window fob control really useful in my last car on hot days as a way to quickly get the cabin temperature down, but, as you say, Citroen make strange cuts depending on region.
This is from the handbook:
► To open the windows, press the unlocking
button for more than 2 seconds (depending on
version).
► Press again to stop the windows opening.
I've also noticed that the HUD loses the ability to display full route navigation if android auto is used, all I get is the turn icon. I'm almost tempted to pay the £90 annually for Citroen Connect Plus so I can use the built in TomTom satnav and get full hud back...
Tigerseye
Hi GPH.
I've had a look this morning and, like you, I can't seem to use either of the features you mention. As you say, it seems hit and miss what Citroen actually activate from country to country. I suppose it would help if they produced an appropriate manual for each area!
The HUD does lose some of the functionality when using Google Maps or some other nav app, although at least it does retain some of the on-screen direction (I think some other cars don't have any).
Anyway, I hope you enjoy the car and have problem-free motoring. There are not many C5X's around at all so it's nice to have something a little different. I've had mine for about 15 months now and have been really happy with it. The only issues I've had so far (hope I'm not jinxing it) is that the boot stuck after the first lock engaged but the second part of the procedure didn't finish. It meant that the car thought the boot was open and so it kept trying to auto lock and unlock it repeatedly, with the alarm occasionally going off. It was sorted through on-call (RAC) arriving and basically slamming his hand against the boot whilst pressing the unlock on the key fob. After that I've always kept the locking mechanism very well-lubricated just in case.
The rear camera has also failed twice but then returned to life weeks after, Perhaps it was water ingress but I'm not sure,
Apart from a few electrical glitches, which is common to most cars these days, which reset after turning off and on, it's been fine. Oh, the US English voice is annoying though - why can't we just have UK English? Tom Tom offer it so why hasn't it been adopted? French quirks I guess (even though it's Chinese!).
Sloppysod
x 400
Unread post by Sloppysod »
GPH_1969 wrote: 14 Nov 2026, 07:23 ...... I'm almost tempted to pay the £90 annually for Citroen Connect Plus so I can use the built in TomTom satnav and get full hud back...
Kep an eye out, Citroën do offers occasionally, there's one around now, £3 a month for 3 months 'OFFER26M'
And... My experience is that only Google mapsg andve accurate turn information, especiallyat roundabouts, others Waze, HereWeGo, Zygo, ........ Don't, possibly Google block.
As for remote control of windows,mine only close if I hold the remote for more than 2 seconds, old C5 (X7) was the same!
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
GPH_1969
Hi Tigerseye and Sloppysod
Thanks again for checking your cars and replying.
Sloppysod - so this works (in part) for you, but not either if us. That's odd. I may pursue this with the salesman at Stellantis & You.
I saw that offer pop up too, although the built in satnav didn't take me to the correct location this morning and reported a 30 mph road as 80(!?), so I suspect I'll save myself the cost and just use Google maps.
The only issue I've found is the rear camera washer isn't working although I can hear the pump going. May just be a failed non-return valve, which happened on my previous car. If so then it's just a couple of quid to replace, as long as I can find out how to locate it.
I only took delivery yesterday, so early days. The Lane Keep Assist had told me off a couple hours of times already, bonging away angrily for about 10 seconds each time. Seriously!?
I'll try put the Adaptive Cruise and Speed Limiter soon. Not sure about the assisted land change feature though, but it may prove worthwhile. Have either of you got on with it?
Cheers.
Tigerseye
Hmm - I'll check again with the window opening/closing on the fob as it didn't seem to work (my last three cars had it and it was occasionally useful).
Adaptive Cruise and Speed Limiter both work well. Highway Driver Assist works very well in my experience, once you have the trust in the system that it will steer itself within the lane markings (ready to take over of course!).
Tbh although I'm aware of the assisted lane change feature, I've never actually used it. It may work well on uncrowded motorways but that seems to be a rarity in the UK these days!
GPH_1969
My last car had Adaptive cruise which worked brilliantly (once I got over the instinctive panic!)
I'll report back next week about the windows after I've spoken to the salesman.
PaulC5
x 709
Unread post by PaulC5 »
Be careful with the feature that keeps the car within lanes, our Skoda with it sometimes sees things like tar marks along the road as a lane marking so if not holding the steering wheel will try to steer between it and something else.
GPH_1969
PaulC5 wrote: 14 Nov 2026, 17:09 Be careful with the feature that keeps the car within lanes, our Skoda with it sometimes sees things like tar marks along the road as a lane marking so if not holding the steering wheel will try to steer between it and something else.
Yep, this seems to be a common complaint with modern cars. My last car at least allowed this to be permanently disabled.
Tigerseye
Yes - care is definitely needed with this feature, especially if set to read speed limits and adjust itself. Travelling down the M1 in my last car (Volvo V90), the system read the limit on the adjacent road (30mph) and braked hard, much to the shock of both the driver behind me and my underwear. So far the Citroen system hasn't done that yet (more modern I suppose) but you need to keep your eyes open to it.
Sloppysod
x 400
GPH_1969 wrote: 14 Nov 2026, 16:26 I saw that offer pop up too, although the built in satnav didn't take me to the correct location this morning and reported a 30 mph road as 80(!?), so I suspect I'll save myself the cost and just use Google maps.
You are not alone, the inbuilt SatNav is absolutely pants compared to Goggle Maps - doesn't get postcodes right either!
GPH_1969 wrote: 14 Nov 2026, 16:26 The only issue I've found is the rear camera washer isn't working although I can hear the pump going. May just be a failed non-return valve, which happened on my previous car. If so then it's just a couple of quid to replace, as long as I can find out how to locate it.
If the garage wont/can't sort it and you need instructions let me know. The pipe is behind the little flap on the inside of the boot I think.
From the owners Handbook
An additional jet is fitted above the number plate to clean the reversing camera (depending on version).
With reverse gear engaged, the washing of the reversing camera is triggered by clicking on this button in the right side menu of the touch screen.
GPH_1969 wrote: 14 Nov 2026, 16:26 I only took delivery yesterday, so early days. The Lane Keep Assist had told me off a couple hours of times already, bonging away angrily for about 10 seconds each time. Seriously!?
Ah, With my Lane Keep Assist it just nudges me back, no Bongs!
GPH_1969 wrote: 14 Nov 2026, 16:26 I'll try put the Adaptive Cruise and Speed Limiter soon. Not sure about the assisted land change feature though, but it may prove worthwhile. Have either of you got on with it?
I have Adaptive Cruise and Speed Limiter, both are very good, especially adaptive cruise in traffic jams, easy-peasy... but do not have the assisted land change feature :cry:
Just so you know, mine was built in September 2022, so it's one of the early cars.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
GPH_1969
Sloppysod wrote: 14 Nov 2026, 18:47
I'll stick with Google Maps then, thanks.
I'll give another try tomorrow. The car was as registered Jan '24 and still under original warranty, so I'm assuming it'll be covered. If not then I'll take you up on your kind offer.
I think I must have strayed egregiously over the line. Do you find it reasonable or turn it off?
land should be lane! How do I determine the build date?
PaulC5
x 709
Land change feature sounds much more fun, flies you through the air to another country.
On one of the door pillars should be a tyre pressure sticker. At the top of this will be the RPO number which can be used in a calculator to give the build date. There will also be the factory code letters from where it was built. An example calculator https://www.mittns.de/core/orga-rechner-en/
GPH_1969
PaulC5 wrote: 14 Nov 2026, 20:18 Land change feature sounds much more fun, flies you through the air to another country.
Thanks for that. Mine says 17115VD, so built 18 Sept 23 which sounds about right given the registration date.
