2021 DS7 Drivers Wing Mirror - disassembly
Monsterlime
Unread post by Monsterlime »
Does anyone know exactly how to disassemble the drivers wing mirror on a 2021 DS7? Wife was driving and someone hit it and essentially just drove off. The glass is broken, indicator cover is broken and part of the mount for the glass is broken, but the body coloured parts are fine.
Have attached the pictures. Really just need to work out how to get the surround and top cover off so I can buy a replacement on ebay, disassemble that and rebuild it. I can see the tabs inside, but it isn't obvious how you do it.
I've already removed the glass, and disconnected the wiring from the broken mount.
Thank you!
x 8155
Re: 2021 DS7 Drivers Wing Mirror - disassembly
Have you had a search on Youtube, quite often there are things like mirror replacement on there. :)
Monsterlime
I've looked, and nothing really helpful. Although, since it is already broken this probably won't hurt to try - :D
Djandree
x 38
Unread post by Djandree »
Here you are
DS 7 CROSSBACK (X74) - C4CS015ZP0 - 1 - 07_03_2018 - Stripping-assembling _ Exterior mirror1.pdf
(432.05 KiB) Downloaded 13 times
DS 7 CROSSBACK (X74) - C4CS015ZP0 - 1 - 07_03_2018 - Stripping-assembling _ Exterior mirror.pdf
(462.17 KiB) Downloaded 13 times
DS 7 CROSSBACK (X74) - C4CG01DRP0 - 1 - 01_03_2018 - Removing - refitting _ Exterior mirror.pdf
(296.97 KiB) Downloaded 11 times
Monsterlime
Thank you, that is fantastic!
Djandree
x 38
You're welcome
Djandree
x 38
found parts numbers catalogue
DS 7 CROSSBACK (X74) - X74E 07 842005A - EXTERIOR REAR VIEW MIRROR PARTS.pdf
(79.11 KiB) Downloaded 11 times
Monsterlime
Thank you! You dont happen to have the door card removal instructions as well, do you? That bit has stumped me.
Djandree
x 38
yes I have. will post it tomorrow
Monsterlime
Brilliant, thanks!
