Wiring harness diagram with color
Calidapee
Post by Calidapee »
Hello i recently got my 2023 PEUGEOT 408 GT
VIN - VR3**************[VIN obfuscated, can be read by forum staff]
The main harness wiring loom which connects with the front bumber wiring loom was cut off from the last user(don’t know why) This is not allowed me complete the rebuild as I can’t seem to match the right wire from the main harness (engine harness) with the front bumber harness. Not all the wires where cut but some of the wires where cut. Pls I need help with the wiring diagram for the engine bay/main harness wiring loom that connects with the front bumber wiring loom.
Front bumper wiring loom
Main/engine harness wiring loom
x 1481
Re: Wiring harness diagram with color
Post by xantia_v6 »
Peugeot wiring does not (with some exceptions) have a standard colour code. The wires are identified by numbers printed on the insulation every 10cm or so. I don't have access to wiring diagrams for your car, but the wire numbers are mostly standard for the same function on all models. So if you can find some code numbers we may be able to identify the function.
ozfrog
(Donor 2026)
x 84
Post by ozfrog »
xantia_v6 wrote: 09 Nov 2026, 06:19 Peugeot wiring does not (with some exceptions) have a standard colour code. The wires are identified by numbers printed on the insulation every 10cm or so.
Many Australian auto electricians have been known to use unkind words to describe Peugeot when they have seen this. I make no other comment.
Cheers,
Andrew
Calidapee
Post by Calidapee »
Thank you for this information
I won the car in auction and didn’t know the wiring loom had been cut off as it was not a feature that I was told about
I have tried looking for the number on the wires but can’t seem to find any number on the wires
I can share some of the fault codes it’s showing hence why I am looking for the wiring diagram for how to match the cut wires from the engine bay:main harness wiring to the front bumper wiring loom that carries the parking sensors, Abs sensor , airbag sensor
Another question I have is does the cut wires coming from the main harness connect directly to the blue pigtail on the front bumper
