Part number help for Citroen C1 (MK II) Aux connector
Lecit
Unread post by Lecit »
Hello,
The aux connector in my Citroen C1 broke and I took it out and it says 9805404777 on it. But the service center told me the 9805404777 itself is not available and maybe I can try 9805404780.
However, they couldn't verify if the 9805404780 comes with the aux connector inside, or if it's just the plastic cover.
I found an example on eBay of the plastic cover that comes without the AUX module itself:
https://www.ebay.com/itm/820317775487
But I do need the connector inside: https://www.ebay.com/itm/254669423246
So I wonder if the 9805404780 does come with the module inside.
OR, maybe 9805404780 is the same as 9805404777?
I can't order the part from eBay, the seller does not ship to me.
x 8155
Re: Part number help for Citroen C1 (MK II) Aux connector
You could try this supplier in Germany as they may be happy to ship it to you: :)
https://www.ebay.co.uk/itm/820094922433
Lecit
mickthemaverick wrote: 05 Nov 2026, 10:17 You could try this supplier in Germany as they may be happy to ship it to you: :)
thank you, I checked - they do not :(
Do you have any idea if the 9805404780 is just the plastic cover or whether it contains the aux module as well?
